10000 NOP instruction detailed description
0.Initial state
-the data bus is selected on read mode to all the blocks and the bus lines are LO
-the SIO are in undefined states
-The exec pulse is not present1.M_clk1 (PC pulse) increments the PC counter and modifies the address of the ROM to the new line
-the memory puts the NOP (0000) on the instruction bus and the afferent data word (XXXXXXXX) on the data bus
-the instruction decoder enables the line no 1
-line 1 is not connected
2.M_clk2 -
3.M_clk3 (Exec pulse) does nothing because all the logical AND gates having this line as an input, are having the other lines LO
4.M_clk4 deactivates (by reset) the R/W lines and all the blocks on the bus are in read mode. -
20001 LTAC
0.Initial state
-The exec pulses are not present1.M_clk1 (PC pulse) increments the PC counter and modifies the address of the ROM to the new line
-the memory puts the LTAC (0001) on the instruction bus and the afferent data word on the data bus before the I/O buffer of the 300 Block
-the instruction decoder enables the line no 2 of the SIO
-line 2 activates two logical and gates at the Enable of the I/O buffer at the output of the Block 300 and at the Enable of the I/O buffer junction
-line 2 also goes into an AND logical gate connected on the parallel load of the AC
2.M_clk2 swithces the I/O junction buffer and the block 300 I/O buffer on through the logical AND gates
3.M_clk3 (Exec pulse)enables the parallel load on AC opening the AND gate
4.M_clk4 deactivates (by reset) the I/O buffer lines and all the blocks on the bus are in read mode.
-this pulse also switches off the I/O junction buffer -
30100 INCAC and 0101 DECAC blocks
0.Initial state
-the memory puts the INCAC (0100) on the instruction bus
-the instruction decoder enables the line no 5
-the junction buffer before the AC and the I/O buffer at block 300 are deactivated by default
2.M_clk2 (Exec pulse) puts the increment pulse on the AC register and opens the I/O output buffer of the Carry flag
-the AC increments
-if the CO output of the AC gives a pulse, the Carry I/O buffer will latch HI
3.M_clk3 (Exec pulse) enables the parallel load on the FLAGS register and this will store the C or Z present flags
4.M_clk4 deactivates (by reset) the I/O buffers and all the blocks on the bus are in read mode.0.Initial state
-the memory puts the DECAC (0101) on the instruction bus
-the instruction decoder enables the line no 6
2.M_clk2 (Exec pulse) puts the decrement pulse on the AC register and opens the I/O output buffer of the Carry flag
-the AC decrements
-if the BO output of the AC gives a pulse, the Carry I/O buffer will latch HI
4.M_clk4 deactivates (by reset) the I/O buffers and all the blocks on the bus are in read mode. -
40110 RRAC and 0111 RLAC block
0.Initial state
-the memory puts the RRAC (0110) on the instruction bus
-the instruction decoder enables the line no 7
-the RRAC module is already loaded with the value of the AC
2.M_clk2 (Exec pulse) puts the rotation result on the input of the AC
3.M_clk3 (Exec pulse) enables the parallel load on the AC through an AND gate and the AC and the FLAGS are storing the result
-the memory puts the RLAC (0111) on the instruction bus
-the instruction decoder enables the line no 8
-the RLAC module is already loaded with the value of the AC
2.M_clk2 (Exec pulse) puts the rotation result on the input of the AC by activating the I/O buffer at the output of the RLAC block
51000 ADD instruction block description
0.Initial state
-the memory puts the ADD (1000) on the instruction bus and the afferent data word (the number B) at the input of the 300 I/O buffer
-the instruction decoder enables the line no 9
-the junction buffer before the AC is deactivated by default
-the number A is found at the output of the AC before the buffer
2.M_clk2 (Exec pulse) activates the I/O buffer of the Block 300 and outputs the number B to the bus
-the pulse also enables the output I/O buffer for this ADD operation block
-This puts the result on the input of the AC
3.M_clk3 (Exec pulse) enables the parallel load on the AC and FLAGS through an AND gate and the AC stores the result
4.M_clk4 deactivates (by reset) the I/O buffers and all the blocks on the bus are in read mode again. -
61001 OR block and 1010 AND block description
0.Initial state
-the memory puts the OR (1001) on the instruction bus and the afferent data word (the number B) at the input of the 300 I/O buffer
-the instruction decoder enables the line no 10
2.M_clk2 (Exec pulse) enables the output I/O buffer for this OR operation block
-the pulse also activates the buffer I/O buffer of the Block 300 and outputs the number B to the bus
3.M_clk3 (Exec pulse) enables the parallel load on the AC through an AND gate and the AC stores the result
0.Initial state
-the memory puts the AND (1010) on the instruction bus and the afferent data word (the number B) at the input of the 300 I/O buffer
-the instruction decoder enables the line no 11
-the pulse also enables the output I/O buffer for this AND operation block
71011 JTO (Jump to) instruction description
0.Initial state
-the memory puts the JTO (1011) on the instruction bus and the afferent data word (the new PC) on the data bus
-the instruction decoder enables the line no 12
-line 12 activates R/W PC line of the block 300 wich goes into a logical AND gate inside the block
2.M_clk2 -
3.M_clk3 (Exec pulse)enables the parallel load on PC through a logical AND gate (connected on R/W PC)
4.M_clk4 deactivates (by reset) the I/O buffer lines and all the blocks on the bus are in read mode.!Atention! the next pulse cycle will increment the PC again with M_clck1.
If you want to reach a certain instruction in the ROM, think of it as PC-1 -
81100, 1101 and 1110, JNZ, JNE and JNC instructions description
These 3 instructions come in a single block and their description matches the order in the title.
0.Initial state
-the memory puts the JNZ (1100) on the instruction bus
-the instruction decoder enables the line no 13
-the JUMP block module is already loaded with the value of the FLAGS
2.M_clk2 (Exec pulse) activates the I/O buffer at the output of the JUMP module
3.M_clk3 (Exec pulse) outputs a pulse that will increment the PC only if the speciffic flag is present
-the memory puts the JNE (1101) on the instruction bus
-the instruction decoder enables the line no 14
-the memory puts the JNC (1110) on the instruction bus
-the instruction decoder enables the line no 15
9Other functional blocks that go into the main schematic
E detect block.
Used for the E (equal) flag. Activates the particular line when the two numbers are identical.
PWR generating clock,
is basically used for powering the entire computer:
Clock generating module:
IO buffer block
It is used as a separation gateway for connecting to the bus. In order to avoid having 2 different blocks talking to he same bus, the unused buses can be disconnected through these serial switches.
10RAM and output port module
This module is not finished yet. The idea would be to have a RAM memory or a stack or register chips working together as a volatile memory. The last address in the memory would be connected to 8 external LEDs and pins. This can be used as the output IO port of a regular microcontroller.
