Hello everyone!
It has been a long process, but all the parts are decided! The components section has been updated with the results. Modeling has also progressed, as the exact measurements for the parts are known. I have decided on using a single bridge pickup as well as a bolt on neck. These decisions were based on the recommendations of others as well as what I thought would be simplest.
The guitar will print in several pieces, the most notable of which will house the pickup and electronics for the lights. Updated pictures are down below, and I will be sure to keep posted as I print and revise the pieces!
