After posting the video from last log, I turned the device off and did not touch it until this morning. I loaded the blink program from eeprom that I demonstrated writing in the video posted in the last log. Running this program, the device ran for 55 min before < 2v power off.
Placing the device in the sun after it went into deepsleep, it powered back on amd resumed the blink program once voltage got over 2v. When the device goes into deepsleep because of low voltage, it deepsleeps and checks voltage every 2 min. This device could easily charge from 2 to 5v in 2 minutes.
I have begun adding build instructions as well as a more detailed components list.
