I figure out how to reach a better frame-rate on the LCD screen. On possibility I didn't tested is to grab the video frames frome the picamera library. I had doubt the RPi zero can transform fast enough the image but it's doing well at 20 fps. There some drops, but very acceptable, and the CPU is at about 40% and 0.7 Load av'.
The code start video recoding :
liveview = LiveView()
camera.start_recording(liveview, format='yuv', resize=SCREEN_SIZE)
and the class LiveView must implements write(self, string) :
class LiveView(object):
def __init__(self):
pass
def write(self, s):
global lcd
image = Image.frombuffer('L', (416, 240), s, "raw", 'L', 0, 1)
image = image.crop((8, 0, SCREEN_WIDTH+8, SCREEN_HEIGHT))
image = ImageOps.invert(image)
image = image.convert('1')
lcd.write(image.tobytes())
def flush(self):
print('Stop LiveView')
The thing about the 416 pixel width instead of the 400 of our screen (and the needed crop) is due to the fact that the camera return a modulo 32 pixels dimension video frames.
Sees v0.6 on github.
