Every once in a while I end up requiring more IO for a prop than my boards have headers for. I've had "make an IO expander for your ecosystem" on the to-do list for a while, but due to time limitations  I've always opted to grab prebuilt solutions to expand my IO, such as a MCP23017 board. Thanks to a recent commission and a sponsor from PCBWay, I pulled this out of the idea box and made it.
Choosing a Solution
Recently I had a client request a full escape room build. Multiple portions of the escape room require more IO than my current boards allow. In the past, I have also had use cases requiring several analog inputs, such as a large array of knock sensors. Looking at some of the solutions for dedicated SMD devices for analog, the price range for such chips ranged between $4-$12 and 4-8 analog inputs with a decent resolution.
Not liking those options, I turned to microcontrollers for their analog offerings. All of the microcontrollers I'm familiar with thus far are lackluster. The Arduino line has low resolution, the RP2040 also has low resolution, and the Espressif microcontrollers are "estimated" analog values and are the least accurate of them all. So, I dug deep into my plastic bin of "microcontrollers I vaguely remember using at one point". Investigating and checking each board out of the bin, I landed on the notorious "Blue Pill" board.
Small bit of history of the Blue Pill board if you're curious:. The Blue Pill board is an STM32 microcontroller cloned from the original design of the [Maple board by Leaflabs](https://www.leaflabs.com/maple/). This was the first board design from Leaflabs in 2009. An Arduino core was created to enable programming via Arduino IDE, and it immediately became a smash hit for hobbyists interested in transitioning from Arduino's 8-bit architecture to a more modern 32-bit architecture. Suffering from its success, clones began to emerge from China at an incredibly low price point with a blue PCB and counterfeit components. However, with the Blue Pill board costing around $1.50 and working "with just a few issues", it took off harder than the Maple boards. Even in 2024, these boards are still floating around while the Maple board retired in 2015.
The microcontroller hosted on these boards is the STM32F103C8. Thanks to its popularity, it's produced in high volumes and is extremely affordable at less than $1 per chip. In terms of features and performance today, it is an average microcontroller perfectly capable of handling any regular task. It's capable of 12-bit analog resolution, which is pretty decent, and especially so for its price. There are two ADCs each with 10 channels, but they share the same pins, putting the microcontroller up to a total of 10 analog inputs (actually 15, but I'll discuss that later). Board to board communication is possible with the device through I2C, UART, SPI, and CAN. It also supports DMA over analog, which means analog sampling can occur in the background without affecting the speed of the rest of the system.
The downside to choosing a microcontroller as an analog solution over a dedicated chip is development time. A dedicated IC needs less components compared to a microcontroller. Going even further, you can also buy fully complete solutions with no development required if you're willing to pay for it. Also, significantly less programming is required to interface with a dedicated IC compared to a microcontroller. That extra couple of dollars you'll spend on the dedicated IC may make up for the time, depending on your situation. My goal is to push down the hardware cost to a minimum to make replacements less impactful and to future-proof the idea of selling boards. Since I can program, design, and execute these solutions, I choose to develop it. This also gives me the freedom of deciding how it will operate.
Designing the PCB
In order to use the STM32F103C8 in a design, a few passive components are required. When working with analog, extra care must be taken in trace routing to reduce noise and interference in order to maintain accurate analog signals. There needs to be a way to program the board, interface with the board, and easily connect analog inputs as well.
Mandatory STM32 Components
The board will be powered from an external 5V source, which will be stepped down with a 3.3V linear regulator. Decoupling capacitors were placed as close as possible to the power pins of both the microcontroller and the linear regulator. The shorter the distance between the path to the capacitors and power pins, the better they will perform in eliminating noise from the power circuitry.
An external oscillator is required to operate the microcontroller at its fastest speed of 72MHz. This is the noisiest component on the board and needs to be isolated properly to prevent its noise from affecting the analog inputs. ST has a good design guide for implementing oscillators in hardware. If you're interested in eliminating noise from a circuit, even if you're not designing a board for an STM32 microcontroller, the recommendations in this guide are applicable to any "isolate a noisy component" situation.
The oscillator must have an isolated ground plane separated from the rest of the board's ground plane, and that ground plane must route directly to an available ground pin on the microcontroller. The recommended way to accomplish this per the design guide is to create a ground ring on the top layer of the board with vias connecting to the isolated ground plane on the bottom. This creates a barrier to catch oscillator noise permeating from the sides and route them into the ground plane instead of making their way to any sensitive signals. The ground plane is then routed to the nearest ground pin on the microcontroller with the shortest distance possible.
Programming Reset, and Boot
There are two ways to program the STM32F103C8: the standard JTAG header or a serial wire interface. Regardless of which method you choose, you'll need an ST-Link adapter to program and debug the microcontroller. The serial wire interface requires less pins than JTAG, so I added the serial wire interface as standard pin headers, ignoring the JTAG interface.
The reset pin is pulled up internally and is activated by pulling the pin to ground. A simple button and debouncing capacitor is utilized for hardware resetting.
In order to flash the microcontroller, BOOT0 must be HIGH and BOOT1 must be LOW. To run the code, BOOT0 must be LOW. I didn't want to be locked out of switching both the BOOT polarities in case I needed all the modes, so I mimicked the Blue Pill board and broke the BOOT pins out with standard header pins which are selected with a jumper.
Inputs
In my current prop board, I chose 3.81mm pluggable terminal blocks by mistake instead of 2.54mm terminal blocks. However, I'm now a fan of the slight size increase as it makes it easier to plug in cables without sacrificing too much board space. Going along with that preference, I chose the same type of terminal block for this board. Terminal blocks for wire connections are not the most cost efficient, but streamlining wire to board connections is essential for setting up and servicing electronics quickly on a work site, so I don't compromise on it.
You won't know ahead of time whether you'll need power, ground or both for sensors interfacing with any given board. Sensors also utilize varying voltages. There are a lot of sensors out there, and each one has its own requirements. It's impossible to account for all of them in a cost effective manner, but we can account for most of them by being compatible with 3.3V, 5V, and 12V. Each input has a resistor network selectable by solder jumpers depending on whether these 3 voltage levels are being delivered by the connected sensor.
Each input also sports a solder jumper for delivering 5V or 12V power to the sensor and a ground. If the sensor is 3.3V, the resistor network can be completely bypassed with another solder jumper, which sends the signal directly to the microcontroller. To keep track of the jumpers, I added a table on the back as a guide to choose which jumpers to solder for a given voltage.
Communication
Since this board's purpose is to receive input data from its input pins to send to other devices, it functions as a slave device. In the niche case where I need to implement more than 10 additional analog inputs, multiple boards should be able to communicate through the same wire. I initially decided on I2C and CAN. I2C is an extremely common method for hobbyists to interface with sensors and peripherals, so this protocol makes sense for myself and others to use.
I also wanted a protocol that allows long distance communication in case a longer cable is necessary, so I initially chose the CAN protocol. However, between CAN and RS485, the latter made more sense for my application and the switch was made after the board was nearly finished. CAN is a masterless protocol where every device is free to communicate over the bus as long as space is provided. However, this board will exclusively behave as a slave device and will have no interest in behaving as a master. With RS485, I can implement the Modbus standard, which is a standardized and accepted method of transmitting data between one master and multiple slaves over an RS485 bus. Modbus is purpose-built for my application, and adopting it enables industrial controllers, PLCs, and computers with an RS485 adapter to interface with it.
In an effort to not lose it, I also added a UART breakout accessible via basic header pins. Adding a USB serial interface is less useful for STM32 since programming isn't possible over UART. Implementing UART over USB also increases cost. With the header pin breakout, however, a serial adapter can be utilized.
Ordering via PCBWay
PCBWay sponsored the cost of the board, which allowed it to leave the idea phase and land on my workbench. In exchange, I'll review my experience ordering an assembled board from PCBWay. Though they didn't request it, I also added their logo on the bottom of the board as recognition of their offer.
Board fabrication
I designed my board through KiCAD 8.0, and PCBWay has an addon available for KiCAD that automatically exports a gerber with settings appropriate for their factory and pushes it to their order page with a click of a button. This is much faster than tediously cross referencing a manufacturer's capabilities page and manually inputting gerber formats, specifying tolerances, and whatnot. Other than selecting cosmetic options on the ordering page, you're good to go.
Speaking of cosmetic options, one thing I enjoy about PCBWay compared to other manufacturers I use is that 7 out of 10 of their solder mask colors do not incur an additional fee. I'm used to the price increasing when switching from the default FR-4 green color of PCBs. Thanks to that, I was able to make this board a red PCB guilt free.
While not utilized in the design, I noticed PCBWay is offering multi-color UV printing. This is an offering I've seen cropping up recently where you can have a color image applied to the top and/or bottom of your PCB via a UV printer. I have a backlog of ideas to implement for props with exposed PCBs, and this will enable a lot of creative liberty in those designs.
The pricing for the various options is more than reasonable for board fabrication. Board size matters when ordering in quantity. The STM32 Analog Slave board is 58.2x78.2mm, and I could choose up to 10 boards at a price point of $0.50 per board before addons. The next option, 15 boards, shoots up to $2.54 per board. Going up to the maximum quantity of board I've ever ordered, 100, the price settles back down to $0.77 per board.
This, however, doesn't factor in the cost of shipping. Shipping 10 boards to my address costs $20.54 with DHL, while shipping 100 boards only increases shipping to $32.20. This brings the price point of 10 boards to $2.55 per board and 100 boards to $1.08 per board. As expected, buying in bulk saves money.
If you're interested in a PCB made of aluminum instead of typical FR-4 and can squeeze your design into a single layer, it costs roughly the same as a two layer FR-4 board. Aluminum boards dissipate heat faster, allowing designs much more leeway when pumping lots of power through them. Don't fabricate a 2+ layer board out of aluminum though, unless you're planning to lose all your vacation money.
While it won't matter to most hobbyists, FR-4 has different types that can resist heat better than others, which can help protect the board under extreme conditions or overexposure to a hot soldering iron. PCBWay automatically upgrades FR-4 to a strong type for free on 2-layer boards, and an even stronger type if your entire order is also larger than 3 square meters in area. I didn't hit the 3 meter benchmark, but if you're ordering in quantity this is a nice touch.
For board thickness, the standard is 1.6mm thick. Increasing the thickness past 1.6mm begins increasing the cost by a nontrivial amount. Decreasing the thickness reduces the price until 0.8mm, and lower than that begins to increase the cost again. I'm surprised 0.2mm thick boards are an option here, because I can't imagine handling a board that thin. Nonetheless, I bet it has incredible applications for electronics in tight spaces.
Minimum track spacing is the same price between 4, 5, 6, and 8mil. If you drop your requirements down to 3mil minimum spacing, the price more than doubles. I played around with this and discovered that a 3.2mm thick board does not increase in price when dropping the minimum spacing to 3mil. If your design requires that tight spacing, take advantage of the thicker PCB.
Minimum via size can drop down to 0.25mm without a price change. 0.2mm bumped the price up by around 40%, and 0.15mm nearly tripled it. Luckily I'm not designing a board with a BGA chip where tiny vias are required to wiggle signals under and around the grid array.
Default silkscreen color changes based on the color of the solder mask you choose. If you choose a non-default silkscreen color, the price bumps up a little.
UV printing on one side is actually the same price as changing the color of the silkscreen. If you want to modify it, you might as well take advantage of this feature and apply a high quality decal on your board with the silkscreen as a part of the image. Applying a UV print to both sides barely increases the price compared to a single side, so have at it.
If your board has an edge connector, a surface finish of HASL with lead does not cost extra. If you want a gold finish for maximum conductivity, expect to sacrifice some bank balance for it. There are several more options between HASL and gold to offer a compromise between price and conductivity.
Vias are tented by default, and requesting them to be exposed does not increase cost. Plugging the vias completely with a solder mask increases the cost a small amount.
The copper thickness of the PCB layers can be increased if the minimum hole size is large enough. Smaller holes are unable to be drilled through thicker copper and stay within specification. The price increase per ounce of copper is fairly linear except for the change from 2 to 3 ounces and 11+ ounces. There is a significant jump at these values. Thicker copper means more power can be pushed through a thinner trace, which can help with squeezing power designs into a smaller footprint.
By default, PCBWay adds a product number to each board for identification purposes. You can remove it for a very small fee or specify a location on your board by adding WAYWAYWAY on the silkscreen of the board design where you want it. I recommend leaving the product number on the board as it helps when calling up the company with issues. Instead, place WAYWAYWAY on your board in a discreet location, like underneath a large component footprint. I placed mine directly under their sponsor logo as it made sense to do so.
Assembly service
While I'm capable of assembling my own SMD boards, it almost always makes more sense for me to take advantage of the manufacturer's assembly service. Utilizing an assembly service is going to be more cost efficient than manually placing the components yourself if your board has more than 5-10 components to place on it. With PCBWay's assembly pricing, this rule remains true. If you're designing a board with assembly service in mind and want to reduce cost there are a few tips to keep in mind.
The KiCAD addon does not help with filling in assembly information. It *does* produce the required bill of materials for assembly and include it, but I found that the information populated by the addon was incorrect. Modifying KiCAD's BOM properties didn't change the addon's behavior. PCBWay provides a good template as an example though, so creating one wasn't too difficult.
You can have PCBWay source the parts in your BOM, ship them to PCBWay yourself, or mix it up. Unless it's strictly necessary, I recommend letting PCBWay acquire the components. They'll know what packaging options work best for their setup, and can take advantage of sourcing components from vendors closer to their location to your benefit.
If you placed all components on one side of the board, the assembly cost is the same. If components are placed on both sides, choosing a double-sided assembly bumped the assembly cost up by about 60% in my sample. That's not too bad, considering the difficulty of assembling components on both sides increases significantly due to gravity. Surface tension can keep very small components secure when upside down during reflow, but otherwise extra means are necessary. It's more than a 60% difficulty increase in my experience.
You can specify if there are components or parts on your board that require more sensitive handling than the default soldering process. Selecting this option does not affect the listed price, but I hypothesize the price is negotiated on a case by case basis in this regard.
PCBWay includes an option to accept alternative parts made in China. I selected this option and throughout the assembly process no parts were substituted. If they can source the parts you specified, they won't do this. I attempted to provoke this option when speaking with the customer service rep handling my assembly order, and I'll detail that exchange in the next section.
The labor cost of assembling a through hole component is more expensive than an SMD component. Barring the cost difference of equivalent components in SMD and through hole form factor, your options are:
  1. Through hole component, but omit it from the assembly list and assemble the through hole component yourself upon arrival.
  2. Through hole component, and they assemble it.
  3. SMD component, but omit it from the assembly list and assemble the SMD component yourself upon arrival.
  4. SMD component, and they assemble it.
Option 3 defeats the purpose of an assembly service, so that option is out. If you can find an equivalent SMD component, this is the best option. If you only have 1-2 through hole components with few pins, option 1 could be your best option. Otherwise, you'll have to pay the additional cost with option 2.
With all options set to 0 or their minimum value, the assembly cost starts at $2.90 per board for 10 boards, drops to $1.40 per board at 20, increases to $1.80 per board at 50, and drops to $1.20 per board at 200. The final breakpoint occurs at 1000 boards at $0.50 per board. Even at the 10 board breakpoint, the price is extremely affordable in terms of assembly.
I'm unable to find a price sheet for assembling the various components on PCBWay, which makes planning around the price of a design difficult, but I was able to play around with numbers on the website to obtain a rough idea. I obtained these breakpoints with my board design inputted. I manually modified the unique parts and component type from 0-1, 1-2, etc. and observed the price change. The exact pricing I obtained may be unique to my board, quantity, order date, and other factors, but can serve as a baseline for others. For "difficult SMD components", this includes BGA chips, components with 20+ pins, and components with tight pin spacing. The only component that passed this threshold on my board was the STM32F103C8 microcontroller, which has 48 pins and tight pin spacing.
Customer Service and Corrections
Throughout the assembly process I had a few back and forth emails with PCBWay. Some were related to the general process, and others were in relation to issues I injected intentionally and unintentionally.
There were some components on the board where the exact part used did not matter. I tested the alternative parts checkbox I selected earlier using these components. As long as the pin headers on my board were the standard 2.54mm pitch, they could come from any vendor as long as they worked. I added the pin headers into the bill of materials but omitted the part number when submitting the order to see if they would handle it. Unfortunately, the representative insisted on a part number and didn't invoke the substitute. I assume this option leans toward parts they struggle to source rather than automatically filling in common parts.
I ended up mistakenly sending them a part number for pin headers with the wrong pitch when correcting this. They ordered the part, then informed me by email of my mistake and allowed me to correct this without extra charge. The cost of that mistake should have been on me for that, but they took it upon themselves to rectify the issue. I sincerely appreciated the forward-thinking customer service.
Once the boards were assembled, PCBWay replied with pictures of the boards assembled to confirm that orientation of components was correct. I'm used to other manufacturers charging for an additional confirmation and having to triple check that the orientations of polarized components I provided were correct. It appears PCBWay confirms with the customer as a part of the service at no charge, which is unexpected and appreciated. Nothing was incorrect or out of place, but it's nice to know I have that extra security when ordering through them.
Delivery and Physical Inspection
Hitting the order button, going through the corrections and confirmations with PCBWay, and packing the boards took about 10 days. This was largely due to time zone differences, since PCBWay is in China and I'm going to bed as they open up. It's no fault on their end; they replied as I closed up and I replied the next day when I woke up. In a standard assembly without error corrections, I would wager the process would take about 5 business days. Pretty standard turnaround for a small run.
PCBWay recommended that I ship through DHL. It was a slightly more expensive shipping option than the rest, but I chose it per their recommendation. Packing the boards, shipping through DHL, and delivery to my door took 3 days. Most of my deliveries from China and neighboring countries take 10-15 days on average, so 3 days is mind bogglingly quick. That package definitely traveled on an airline.
Upon opening the package, every board was enclosed in a Ziploc antistatic bag, and the box itself was sufficiently bubble wrapped. Each board was cleaned post assembly with no flux residue. All of the solder joints were solid, no pins were bridged together, and the through hole joints were textbook in shape. The I2C and RS485 terminal block headers were slightly misaligned on a few boards, but I was able to heat up the joints and push them straight.
On every board there were fingerprint smudges on both sides. You might think this is a criticism, but this is actually a good sign. This means a human handled and inspected this board instead of being directly tossed in the shipping box without a thought. I had silently assumed that PCBWay only inspected the one board they sent me images of, but based on the fingerprints I was mistaken. They also left me an extra unpopulated PCB in the box. This wasn't a useful addition, but it's nice to have a reference piece without the visual clutter of components in the way. I could see it used as a way to label a clear plastic container indicating what boards are inside if stuck to the front.
Programming
I had two options to choose from to program the board: the manufacturer's official toolchain with STM32CubeIDE, or the STM32 Arduino core with Arduino. I chose the manufacturer's toolchain. While I have no experience using their toolchain, I enjoy how easy the hardware planning is with their project wizard. If there are any sort of limitations they're automatically flagged in the project, such as UART2 and certain ADC1 channels not being able to activate at the same time or I2C preventing the use of system wake-up. I also wanted to get experience with their software in case I use more of their products at a later date, which is highly likely as I continue to develop boards.
Analog with DMA
By default, STM32CubeIDE generates code that initializes DMA and analog configurations when selected, but it does not start it. In order to do so, you need an array with enough space to store the values read via the analog inputs.
Once started, a DMA interrupt function in a file called `stm32f1xx_it.c` is called when the analog values are finished being read. I set the DMA to circular mode in the project wizard, so this continues indefinitely, calling the interrupt at the end of each cycle. It's best practice to not put any heavy operations inside an interrupt function, so I simply set a flag to indicate that the ADC has finished a full read.
void DMA1_Channel1_IRQHandler(void)
  /* USER CODE BEGIN DMA1_Channel1_IRQn 0 */
  /* USER CODE END DMA1_Channel1_IRQn 0 */
  HAL_DMA_IRQHandler(&hdma_adc1);
  /* USER CODE BEGIN DMA1_Channel1_IRQn 1 */
  flag_adc_ready = 1;
  /* USER CODE END DMA1_Channel1_IRQn 1 */
In the main loop, the flag is checked. If the flag is raised, the data is stored, and the flag is lowered.
while(1)
  if(flag_adc_ready)
    flag_adc_ready = 0;
    for(int i=0; i<10; i++)
       * Write analog vals to input registers
      modbus_input_reg[i] = (uint16_t)analog_buf[i];
Analog to Digital
Since it's easy to do so, I also implemented an analog threshold value roughly half of the maximum analog value. With this, I can plug in boolean inputs, such as buttons or switches, and utilize them with the same board. This board is a bit overkill for the purposes of identifying boolean inputs, but I could have scenarios where I need additional analog inputs as well as boolean inputs. Having one board handle both will reduce build complexity.
while(1)
  if(flag_adc_ready)
    flag_adc_ready = 0;
      * Write digital vals to input states
      if(analog_buf[i] > modbus_holding_reg[MODBUS_IO1_THRESH + i])
        modbus_input[0] |= (uint16_t)(1 << i);
      else
        modbus_input[0] &= (uint16_t)(1 << i) ^ 0xFFFF;
I2C with Interrupts
By default, STM32CubeIDE generates code that initializes I2C, but it does not enable the interrupts, so the appropriate function is added.
In order to act as an I2C slave, first we need to decide how it will communicate with a master requesting data. To get the board off the ground, I took the approach of command and value. The I2C request from the master will consist of:
Each request will be a static size. If the master requests the value of an input pin, the last request byte will include the 0-index of the analog pin to send to the master.
In case the master needs to read the settings in the device, the last request byte will include the 0-index of the settings register to read.
static int i2c_rx_callback(void)
  int command = I2C_rxData[0]; // I2C command
  int val = I2C_rxData[1];  // Input# to act upon
  if (val>9)  // There are a total of 10 inputs (0-9)
    // invalid input, clear and exit
    memset(I2C_rxData,'\0', I2C_RX_SIZE);
    // rxcount = 0;
    return 1;
  switch(command)
    case I2C_READ_VAL:
      I2C_txData[0] = (analog_buf[val] >> 8) & 0xFF;
      I2C_txData[1] = analog_buf[val] & 0xFF;
      break;
    case I2C_READ_CONFIG:
      I2C_txData[0] = (modbus_holding_reg[val] >> 8) & 0xFF;
      I2C_txData[1] = modbus_holding_reg[val] & 0xFF;
      break;
    case I2C_WRITE_CONFIG:
      // Unable to write in current structure
      break;
    default:
      return 1;
  if(command == 255) // Reset MCU
    HAL_NVIC_SystemReset();
  return 0;  // success
Additional interrupt functions need to be populated for:
These are cookie cutter functions added to facilitate I2C communication, and are included in the code.
void HAL_I2C_ListenCpltCallback(I2C_HandleTypeDef *hi2c)
  HAL_I2C_EnableListen_IT(hi2c);
void HAL_I2C_AddrCallback(I2C_HandleTypeDef *hi2c, uint8_t TransferDirection, uint16_t AddrMatchCode)
  if(TransferDirection == I2C_DIRECTION_TRANSMIT)
    memset(I2C_rxData,'\0',I2C_RX_SIZE);
    rxcount = 0;
    txcount = 0;
    HAL_I2C_Slave_Sequential_Receive_IT(hi2c, I2C_rxData+rxcount, 1, I2C_FIRST_FRAME);
  else
    rxcount = 0;
    txcount = 0;
    HAL_I2C_Slave_Sequential_Transmit_IT(hi2c, I2C_txData+txcount, 1, I2C_FIRST_FRAME);
void HAL_I2C_SlaveTxCpltCallback(I2C_HandleTypeDef *hi2c)
  txcount++;
  HAL_I2C_Slave_Seq_Transmit_IT(hi2c, I2C_txData+txcount, 1, I2C_NEXT_FRAME);
void HAL_I2C_SlaveRxCpltCallback(I2C_HandleTypeDef *hi2c)
  rxcount++;
  if(rxcount < I2C_RX_SIZE)
    if(rxcount == I2C_RX_SIZE-1) // Last expected data byte
      HAL_I2C_Slave_Seq_Receive_IT(hi2c, I2C_rxData+rxcount, 1, I2C_LAST_FRAME);
    else // More data bytes
      HAL_I2C_Slave_Seq_Receive_IT(hi2c, I2C_rxData+rxcount, 1, I2C_NEXT_FRAME);
  if(rxcount == I2C_RX_SIZE) // Process on expected stop pos
    i2c_rx_callback();
void HAL_I2C_ErrorCallback(I2C_HandleTypeDef *hi2c)
  uint32_t ret = HAL_I2C_GetError(hi2c);
  if(ret == 4)  // AF error
    if(txcount == 0)  // error is while slave is receiving
      i2c_rx_callback();
    else // error while slave is transmitting
      // Nothing to do here!
  else if(ret == 1)  // BERR Error
    HAL_I2C_DeInit(hi2c);
    HAL_I2C_Init(hi2c);
    memset(I2C_rxData,'\0',I2C_RX_SIZE);  // reset the Rx buffer
    rxcount = 0;  // reset the count
Modbus with Interrupts
In order to use modbus, UART needs to be enabled. By default, STM32CubeIDE generates code that initializes UART, and no additional functions are needed to enable the interrupts.
STM32 does not include a standard RS485 or modbus library by default, so I created functions to facilitate modbus communication. The proper procedures to implement modbus are outlined in [this technical document](https://modbus.org/docs/PI_MBUS_300.pdf) on the modbus organization's official website. In its most basic form, we need to implement the following:
Registers, Coils, and Inputs
Translating the definitions of these data types into our use case, we need to implement the following data types:
For the holding registers, I implemented the following settings:
No thorough planning is required for the coils and inputs. It makes sense to stick with the philosophy of index 0 representing physical input 0 and so on for organization and programming purposes.
The modbus documentation lists specific modbus controllers and their maximum available registers, coils, and inputs. My board is none of these controllers, therefore I need to set the maximums myself. I took a quick glance online at what regular users of modbus threw out as their understood maximum values and implemented these maximums. Per the modbus specification, I need to implement these in order to send error messages when invalid parameters are sent.
#define READ_COIL_STAT_MAX 200 // 200 coils
#define READ_INPUT_STAT_MAX 125 // 125 inputs
#define READ_HOLDING_REG_MAX 125 // 125 registers
#define READ_INPUT_REG_MAX 125 // 125 registers
#define FORCE_SINGLE_COIL_MAX 1 // 1 coil
#define PRESET_SINGLE_REG_MAX 1 // 1 register
#define READ_EXCEPT_STAT_MAX 8 // 8 coils
#define FORCE_MULT_COIL_MAX 200 // 200 coils
#define PRESET_MULT_REG_MAX 60 // 60 registers
Modbus Functions
Each modbus message is capped with a CRC16 value for error correction. These values, and an example function written in C to generate an appropriate CRC16 are located at the bottom of the modbus specification document. I ripped the example out directly and modified the data types to satisfy the STM32CubeIDE compiler.
static uint16_t CRC16(uint8_t *puchMsgg, uint16_t usDataLen)
  uint8_t uchCRCHi = 0xFF; /* high byte of CRC initialized */
  uint8_t uchCRCLo = 0xFF; /* low byte of CRC initialized */
  uint32_t uIndex; /* will index into CRC lookup table */
  while (usDataLen) /* pass through message buffer */
    uIndex = uchCRCHi ^ *puchMsgg++; /* calculate the CRC */
    uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex];
    uchCRCLo = auchCRCLo[uIndex];
    usDataLen--;
  return (uchCRCHi << 8 | uchCRCLo);
To send a modbus message, the message first needs to be populated with data based on the command from the master. That information is then capped with the CRC16. The RS485 module is set to transmit mode by driving the direction pin HIGH. The modbus message is transmitted via the connected UART, and the RS485 module is returned to receive mode.
static void modbus_send_data(uint8_t *data, uint16_t size)
  uint16_t crc = CRC16(data, size);
  data[size] = crc & 0xFF;
  data[size+1] = (crc >> 8) & 0xFF;
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8, GPIO_PIN_SET);
  HAL_UART_Transmit(&huart1, data, size+2, 1000);
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8, GPIO_PIN_RESET);
The methods to read an input or holding register are the same with only a few substitutions, so they're bundled together in the same function. We determine what register the master wants to start reading as well as how many registers it wants to read, starting at that register. If it attempts to access registers outside the maximum amount of registers, we send an error message instead. If the request is good, we create a payload containing our slave address, the original command, the byte length of the data and the data to send. The message is then sent.
uint8_t modbus_read_register(uint8_t reg_type)
  uint16_t startAddr = uart_rxData[3] | (uart_rxData[2] << 8); // starting reg to read
  uint16_t dataLen = uart_rxData[5] | (uart_rxData[4] << 8); // # of regs to read
   * Determine read type
  uint16_t *modbus_reg = NULL;
  uint16_t max_size;
  switch(reg_type)
    case READ_HOLDING_REG:
      modbus_reg = modbus_holding_reg;
      max_size = READ_HOLDING_REG_MAX;
      break;
    case READ_INPUT_REG:
      modbus_reg = modbus_input_reg;
      max_size = READ_INPUT_REG_MAX;
      break;
    default:
      return ILLEGAL_FUNCTION;
      break;
   * Check message validity
  if(!dataLen || dataLen > max_size)
    modbus_exception(ILLEGAL_DATA_VAL);
    return ILLEGAL_DATA_VAL;
  if(startAddr+dataLen-1 > max_size)
    modbus_exception(ILLEGAL_DATA_ADDR);
    return ILLEGAL_DATA_ADDR;
   * Load UART data
  uint16_t uart_index = 3;
  uart_txData[0] = SLAVE_ADDR;
  uart_txData[1] = reg_type;
  uart_txData[2] = dataLen * 2;
  for(int i=0; i<dataLen; i++)
    uart_txData[uart_index++] = (modbus_reg[startAddr] >> 8) & 0xFF;
    uart_txData[uart_index++] = modbus_reg[startAddr] & 0xFF;
    startAddr++;
  modbus_send_data(uart_txData, uart_index);
  return 0;
Reading coils and inputs are also similar, and can be bundled in the same function. Coils and inputs are stored bit by bit rather than in words, so we need to extract the values from each bit of a byte. Otherwise, the payload is structured the same as when we read registers. Once we construct the payload, the message is sent.
uint8_t modbus_read_state(uint8_t reg_type)
  uint8_t *modbus_reg = NULL;
  uint16_t max_size;
  switch(reg_type)
    case READ_INPUT_STAT:
      modbus_reg = modbus_input;
      max_size = READ_INPUT_STAT_MAX;
      break;
    case READ_COIL_STAT:
      modbus_reg = modbus_coil;
      max_size = READ_COIL_STAT_MAX;
      break;
    default:
      break;
   * Load UART data
  memset(uart_txData, 0, 256);
  uart_txData[2] = (dataLen / 8) + ((dataLen % 8) ? 1 : 0);
  uint16_t data_byte = startAddr / 8;
  uint8_t data_bit = startAddr % 8;
    uart_txData[uart_index] |= ((modbus_reg[data_byte] >> data_bit) & 0x01) << (i % 8);
    data_bit++;
    if(i && !(i % 8)) // Loaded a full byte, increase uart index
      uart_index++;
    if(data_bit > 7) // At end of data byte, goto next byte
      data_byte++;
      data_bit = 0;
  modbus_send_data(uart_txData, uart_index+1);
  return 0;
When writing a register, we need to check if the data being written to the register is valid in our board's specifications. We wouldn't want to write a value to an analog input threshold that is larger than 4095, the maximum possible value, for example. Therefore we create a function to pass in the values that fails and sends an error message if invalid.
uint8_t modbus_validate_register(uint16_t holding_reg, uint16_t value)
  if(holding_reg >= MODBUS_IO1_THRESH && holding_reg <= MODBUS_IO10_THRESH)
    // Threshhold value cannot be 0 or exceed the maximum analog val
    if(!value || value >= ANALOG_MAX)
    else
      return 0;
  if(holding_reg >= MODBUS_SAVE && holding_reg < MODBUS_CONFIG_MAX)
    // The only valid toggle for a flag is 1
    if(value != 1)
    else
      return 0;
  // Cannot access nonexistent configuration registers
  if(holding_reg >= MODBUS_CONFIG_MAX)
  // Accessing a valid register with no value restrictions
  return 0;
The number of registers to read is excluded from the master payload when writing to a single holding register since the size is constant. After validating the data, we write the provided value to the register, then echo the master payload without the values written to the master to represent a successful write.
uint8_t modbus_write_single_register(void)
  uint16_t regAddr = uart_rxData[3] | (uart_rxData[2] << 8); // reg to write
  if(uart_rxData[1] != PRESET_SINGLE_REG)
    modbus_exception(ILLEGAL_FUNCTION);
  if(!regAddr || regAddr > READ_HOLDING_REG_MAX)
   * Write holding register
  uint16_t value = (uart_rxData[4] << 8) | uart_rxData[5];
  uint8_t ret = modbus_validate_register(regAddr, value);
  if(ret)
    modbus_exception(ret);
    return ret;
  modbus_holding_reg[regAddr] = value;
   * Load UART data
  for(int i=0; i<6; i++)
    uart_txData[i] = uart_rxData[i];
  modbus_send_data(uart_txData, 6);
  return 0;
Writing to multiple holding registers adds the number of registers to read back into the master payload, with a value to write for each register. We loop through the specified registers writing each value, then echo the master payload without the values written to the master to represent a successful write.
uint8_t modbus_write_multiple_register(void)
  uint16_t startAddr = uart_rxData[3] | (uart_rxData[2] << 8); // start reg to write
  uint16_t dataLen = uart_rxData[5] | (uart_rxData[4] << 8); // # of regs to write
  if(uart_rxData[1] != PRESET_MULT_REG)
  if(!dataLen || dataLen > READ_HOLDING_REG_MAX)
  if(startAddr+dataLen-1 > READ_HOLDING_REG_MAX)
  uint8_t uart_index = 7;
    uint16_t value = (uart_rxData[uart_index] << 8) | uart_rxData[uart_index+1];
    uint8_t ret = modbus_validate_register(startAddr, value);
    if(ret)
      return ret;
    modbus_holding_reg[startAddr++] = value;
    uart_index += 2;
   * Load UART data
  return 0;
Saving Settings
Flash memory on the microcontroller is significantly more robust than RAM, and we don't need to access this data with low latency, so we'll store data in flash. Per the STM32F103C8 datasheet, there are 64 "pages" of flash memory each containing 1024 bytes of flash. When we program the microcontroller, by default, the executable program is stored starting at the start address until it is completely written.
If we want to utilize flash to store data, we need to make sure we use data that isn't in use by the executable. We want to store the data in the modbus holding registers, which contains a maximum of 250 bytes of data, so a single page of flash will suffice for storing data. To minimize the chance of touching the executable code, we'll store values in the final page of flash.
To "load" modbus data, we need to copy the contents of the flash memory at the correct address to the modbus holding register variable. In case we've never saved data here before, we include default values to replace invalid ones.
