Haven't worked on this for a while, but I did make progress on the motors. At first I just hollowed 2x4 lego bricks and fit a small motor inside. I invested in a 3d printer and after learning that somewhat, I was able to start making these (Pic below) Next I am going to work on a casing for the electronics that would also work with legos. So far, I haven't had much luck with due to warping and shrinkage. After the part is printed, the fit isn't quite right. I had better luck with the smaller motor blocks after I adjusted some settings and made a few small modifications to the size of the pegs. Since this is one of my next projects, Im hoping to have it done soon.
I_void(warranties)
