Automatrino - low-dependency automation
Multi-tenant/multi-user remote control, automation, and sensor logging that's easy to set up and get running on a server you control.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
If you want complete control of all the code of a robust multi-user/multi-tenant remote-control, automation and weather data logging system, you might be interested in this system. I developed it to more efficiently use solar energy at my off-grid Adirondack cabin while also keeping the internet accessible and the pipes from freezing. This started out as a simple multi-probe weather monitoring system (ESP8266 MicroWeather) to which I added first reliability automation (Hotspot-Watchdog), then remote control, then solar inverter monitoring, then cabin automation, and finally a multi-tenant security model (so others could use the same server installation as a backend).
Rich text editor
