Now it is polyphonic!
A project log for Arduino (ESP32) Standalone Accordion
Polyphonic Piano Accordion made from a cheap Melodica, some buttons and an ESP32 microcontroller
bruno-campidelliBruno Campidelli 09/03/2024 at 09:460 Comments
Quick one here, now it is polyphonic!
Here is the sound (I am trying to replicate this recipe from Floyd Steinberg, not there yet).
And the sketch (that only works like this, when I try to separate it in classes it doesn't perform well):
#include "MozziConfigValues.h"
#define MOZZI_AUDIO_MODE   MOZZI_OUTPUT_I2S_DAC
#define MOZZI_I2S_PIN_BCK  26
#define MOZZI_I2S_PIN_WS   25
#define MOZZI_I2S_PIN_DATA 22
#define MOZZI_CONTROL_RATE 2048
#include <Arduino.h>
#include <WiFi.h>
#include <Mozzi.h>
#include <Oscil.h>
#include <ADSR.h>
#include <mozzi_midi.h>
#include <tables/saw2048_int8.h>
#include <tables/square_no_alias_2048_int8.h>
#include "Esp32SynchronizationContext.h"
#include "Keyboard.h"
#define LED_PIN           2
#define MAX_VOICES        10
#define SAMPLE_RATE       SAW2048_NUM_CELLS
#define VOLUME            0.95f
// Envelope parameters
unsigned int attackTime      = 50;
unsigned int decayTime       = 200;
unsigned int sustainDuration = 8000;
unsigned int releaseTime     = 200;
byte attackLevel             = 96;
byte decayLevel              = 64;
// Voice structure
struct Voice {
    Oscil<SAMPLE_RATE, AUDIO_RATE> osc1;
    Oscil<SAMPLE_RATE, AUDIO_RATE> osc2;
    ADSR<CONTROL_RATE, AUDIO_RATE> envelope;
    byte note;
    long triggeredAt;
Voice voices[MAX_VOICES];
// Thread-safe synchronization context
Esp32SynchronizationContext syncContext;
bool updateRequested = false;
Keyboard keyboard;
// Finds a free voice. It can be either a voice not in use
// or the oldest one if all of them are being used
int getFreeVoice() {
  int voiceIndex = -1;
  long oldestTriggeredAt = millis();
  for (int i = 0; i < MAX_VOICES; i++) {
    if (!voices[i].envelope.playing()) {
      return i;
    } else if (voices[i].triggeredAt < oldestTriggeredAt) {
      oldestTriggeredAt = voices[i].triggeredAt;
      voiceIndex = i;
  return voiceIndex;
void noteOn(byte note) {
    if (voices[i].envelope.playing() && voices[i].note == note) {
      // This note is already being played, ignore
      return;
  int freeVoice = getFreeVoice();
  float frequency = mtof(float(note));
  voices[freeVoice].osc1.setFreq(frequency);
  float detuneFactor = pow(2.0, 10.0 / 1200.0);
  voices[freeVoice].osc2.setFreq(frequency * detuneFactor * 2);  // 10 cents detuned + 1 octave up
  voices[freeVoice].envelope.noteOn();
  voices[freeVoice].note = note;
  voices[freeVoice].triggeredAt = millis();
  digitalWrite(LED_PIN, HIGH);
void noteOff(byte note) {
    int activeNotes = 0;
        if (note == voices[i].note) {
            voices[i].note = 0;
            voices[i].envelope.noteOff();
        activeNotes += voices[i].note;
    if (activeNotes == 0) {
        digitalWrite(LED_PIN, LOW);
// Callback functions for handling key press and release events
void onKeyPress(int key) {
    byte note = key + 60; // key 0 == C4 == 60
    noteOn(note);
void onKeyRelease(int key) {
    noteOff(note);
void updateControl() {
    if (!syncContext.update()) {
        Serial.println("Could not update synchronization context");
    if (updateRequested) {
        keyboard.update();
    // Update the envelopes
      voices[i].envelope.update();
AudioOutput updateAudio() {
    long outputSample = 0;
    // Accumulate sample values from all playing voices
        if (voices[i].envelope.playing()) {
            outputSample += (voices[i].osc1.next() + voices[i].osc2.next()) * voices[i].envelope.next();
    outputSample *= VOLUME;
    return MonoOutput::fromNBit(24, outputSample);
void updateKeyboardTask(void *state) {
    // RUNS ON OTHER CORE
    while (true) {
            delay(1); // Feed watchdog
            continue; // Don't do anything if the main thread is still processing the last update
        // Request the main thread to update keyboard states
        syncContext.send(
            [](void *state) {
                // RUNS ON MAIN CORE
                updateRequested = true;
        delay(10); // Feed watchdog
void setup() {
    Serial.begin(115200);
    WiFi.mode(WIFI_OFF); // Disable WiFi to conserve power for audio and touch updates
    // LED debug
    pinMode(LED_PIN, OUTPUT);
    // Initialize the Keyboard object and set the callbacks
    keyboard.init();
    keyboard.onKeyPress(onKeyPress);
    keyboard.onKeyRelease(onKeyRelease);
    // Initialize the voices
    for (unsigned int i = 0; i < MAX_VOICES; i++) {
        voices[i].osc1.setTable(SAW2048_DATA);
        voices[i].osc2.setTable(SQUARE_NO_ALIAS_2048_DATA);
        voices[i].envelope.setADLevels(attackLevel, decayLevel);
        voices[i].envelope.setTimes(attackTime, decayTime, sustainDuration, releaseTime);
    if (!syncContext.begin()) {
        Serial.println("Error initializing synchronization context");
        while (true) {
            ; // Halt
    // Create a task on the first core to asynchronously update touch states
    xTaskCreatePinnedToCore(
        updateKeyboardTask,  // Function that should be called
        "Keyboard Updater",  // Name of the task (for debugging)
        1000,               // Stack size (bytes)
        NULL,               // Parameter to pass
        1,                  // Task priority
        NULL,               // Task handle
        0                   // Core
    startMozzi(CONTROL_RATE);
void loop() {
    audioHook();
Next step: I may start creating the Stradella bass....
