Harvesting old laptop lithium batteries - part 1
A project log for Arduino (ESP32) Standalone Accordion
Polyphonic Piano Accordion made from a cheap Melodica, some buttons and an ESP32 microcontroller
bruno-campidelliBruno Campidelli 09/17/2024 at 00:250 Comments
I would like to have batteries inside my Arduino Accordion eventually. As I am still waiting for some 10K resistors to arrive from China, I have decided to see if I could find some batteries around.
I opened an old (and broken) laptop to see what type of battery it had inside. This is the one:
That is the best image I got from the Internet and the specs can be read.
Then I proceeded to open it (be careful to not puncture the Lithium Polymer cells! They can explode!). I have cut one thumb and an index finger in the process, be careful...
These are Samsung batteries model ICP103450S. I managed to find a nice manual for it.
Each one could hold 2000 mAh (when new, I don't know if these are dead or not).
Multimitre time and, as expected, they are sort of dead (they read between 1.7 and 1.8 volts). So I found a very interesting article describing how to "revive" these https://www.instructables.com/Recovering-Lithium-Ion-Batteries/.
It turns out that I don't have that fancy battery charger. What I have instead is this little module here:
So, according to this video, I can reduce the charging current from 1A to 130mA using a 10k resistor. This other video shows how to replace the resistor. Since this battery supports (when new) a charging current of 1700mA, this should be enough to charge it very very slowly and prevent an explosion (I hope!).
So, here is the board with the new 10k resistor:
And here is the video of the charging process (these clamp multimeters don't work so well with low currents, but we can see it is less than 1A now):
Now I am going to wait and monitor to see how it goes.
TBC...
