Build a Better Better keyboard!
A project log for CL-32
A mobile dev terminal, hacker device, anything you like!!
mooseprmoosepr 11/26/2024 at 22:221 Comment
So in the absence of fancy moulded silicone keyboard membranes, Im still on the hunt for a good keyboard experience
The hunt has slowed a little, the re-desgn of the pcb has been taking up my hacking time but I managed to make some amendments.
Your mission, should you choose to accept it..
The task is a fun one, The printer can do features down to 0.5mm, which gives plenty of scope for playing., but if you dont leave big enough gaps, they will fill with the printing powder and at best be hard to remove, and at worst clog up all together.
The buttons are 5.4mm square, and i decided that the central shaft that activates the snap dome is 2mm in diameter. That already limits things somewhat!!
The next limitation is the space below the button. With just 2.4mm between the bottom of the button and the pcb, which will reduce by 0.25mm when the button activates.
Anyone following along at home will have seen my last attempt, which failed because of too much reliance on the 0.5mm minimum feature size (too fragile) and not leaving enough clearance (blocked up the gaps)
After many different attempts I think this might work
Im hoping that there is enough material to stop the buttons falling off, but enough flex to actually work as buttons
New Materials...
I had an email from my local printer guy (Shout to Paul @ Midlands 3d) and he has a new toy!! The last prints were done in nylon using magical HP MJF printers. The new printer opens up SLS printing in TPU, resulting in flexible prints with similar accuracy. The prints have been ordered, and its just a case of waiting to see how they turn out.
To be continued.....
Gordon wrote 11/27/2024 at 18:36 point
Man I am loving following this project, excited to see how these turn out!
I was thinking this device could be used as a great messaging device, if there was some API to send and receive messages, maybe something like signal or discord...
Also a mobile programming/dev terminal is great. I have several Smart Response XE devices, with Arduino BASIC. So much fun to write up programs on such a limited device. That device has a nearly full keyboard, as well as a non backlit monochrome LCD, battery lasts for a long time. Your ESP powered device has much more possibilities, much more capable chip!
