Hackaday.io Hackaday.io
Sign up Log in
Altoids Style Tin CRT Video Glitcher
Based on the 1970s radio shack Video Enhancer. A very Low parts count Analog video Glitcher for AV Equipment.
neil-mundtNeil Mundt
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 10
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
850
0
2
2
Team (1)
  • neil-mundtNeil Mundt
Join this project's team
hardware
ongoing project
eurorack Synth modular stem education synthesizer analog VHS dvd Glitcher Glitch synthwave
This project was created on 08/20/2024 and last updated 2 years ago.
Description
-Features-
*Customizable DIY Analog Video Glitcher
*Fits inside Altoid Syle Mint Container or Completely usable as just the Self Contained PCB.
*Simple THT parts and Low part count to get that simple Analog AV Glitch on a CRT TV.
*Very compact PCB with Ability to patch different components for different glitch effects.
*Works on 12v or 9v battery.
*Add as many buttons or house in bigger container
Why I made it?
I wanted to have a self contained PCB or one that could be housed in any-type of Reusable Tin.
This very simple circuit has been floating around for sometime and wanted to do a simple version before I make a more complex one that has Voltage Control for the Glitching.
Project Logs
Collapse
  • Decent idea with reusing these Pocket prototyping Tins
    Neil Mundt • 02/10/2025 at 18:34 • 0 comments
    Get your pocket calculators out and let's have some fun. These tins are a really good base to have a glitch card on it with mini breadboard. Even has storage for putting away components when not in use. Too bad a 9 volt doesn't fit in the case that would be perfect.
    0
  • Thanks to PCBway I was able to get some more prototype PCBs
    Neil Mundt • 02/09/2025 at 06:33 • 0 comments
    Still working on assembling a few different models. Love that I added this backup cam to the glitcher. Also came up with a base for a traveler Glitch card. It has a nice base and a breadboard for connections and a aluminum case to store extra patch components. Kinda like a pocket Synth glitcher.
  • Been Messing around With Video Glitching and
    Neil Mundt • 01/22/2025 at 01:40 • 0 comments
    This is my Current Analog Glitching Prototyping Platform. Still waiting for parts but I really like the way I found a use for reusing my prototype PCBs.  Just A little Bit of hot glue and nail polish and you have a Slime Display.
  • Been Messing with My APC and Analog Glitcher as a patchbay
    Neil Mundt • 12/15/2024 at 03:28 • 0 comments
    Been Messing around using my APC Atari Punk Console Semi-Patchable SynthCard with my Analog Glitcher and have been having a great time glitching with the LFO and 556 timer oscillator. I really like the Hot glue Goo aesthetic I have going on with this patch board. Working on this layout before refining my all in one glitchers.
  • Doing a lunch kit ANALOG Glitcher
    Neil Mundt • 10/14/2024 at 05:57 • 0 comments
    Been doing an lunch kit analog glitcher with the Rev 1 Pcbs. It's going to have 2 glitchers inside of it. One a built in camera and the other for a vhs. The two knobs on the left bottom are for signal mixing. The right bottom is button glitches and switch glitches. The Inputs and outputs are on the top. It's going to be awesome once completed.
  • Re-Design of the PCB for fitting the Battery.
    Neil Mundt • 09/27/2024 at 03:13 • 0 comments
    Re-doing the PCB so the battery fits better. You should be surprised how little room is in a Altoids tin. But I think I will be able to make it work just need some time for paper revisions. Only thing now is the pcb gonna be less ergonomic. But that is okay Because I will also sell the First version PCBs. Because they work no problem with larger tins.
  • First prototype boards just got in and are working great. Thanks to PCBway for the prototypes.
    Neil Mundt • 09/21/2024 at 00:45 • 0 comments
    Probably gunna change the pcb layout a bit need to rethink the pcb shape to fit into an altoids container. The PCB is pretty much good to go as a standalone pcb or be housed in a bigger tin. Good thing I only ordered 5. Gotta be careful the first prototype PCB. Its quite fun sticking components into the headers and making glitch connections. Nice having it like a mini patchbay.
  • First Prototype Ordered Here is a Gif
    Neil Mundt • 09/14/2024 at 18:34 • 0 comments
  • Paper Mockup of The Glitcher Tin
    Neil Mundt • 08/26/2024 at 02:49 • 0 comments
  • Basic Measurements For a Basic container
    Neil Mundt • 08/22/2024 at 23:36 • 0 comments
View all 10 project logs
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Altoids Style Tin CRT Video Glitcher", please tell us the reason.
Send message
Remove Member
