Based on the 1970s radio shack Video Enhancer. A very Low parts count Analog video Glitcher for AV Equipment.
Get your pocket calculators out and let's have some fun. These tins are a really good base to have a glitch card on it with mini breadboard. Even has storage for putting away components when not in use. Too bad a 9 volt doesn't fit in the case that would be perfect.
0
Still working on assembling a few different models. Love that I added this backup cam to the glitcher. Also came up with a base for a traveler Glitch card. It has a nice base and a breadboard for connections and a aluminum case to store extra patch components. Kinda like a pocket Synth glitcher.
This is my Current Analog Glitching Prototyping Platform. Still waiting for parts but I really like the way I found a use for reusing my prototype PCBs. Just A little Bit of hot glue and nail polish and you have a Slime Display.
Been Messing around using my APC Atari Punk Console Semi-Patchable SynthCard with my Analog Glitcher and have been having a great time glitching with the LFO and 556 timer oscillator. I really like the Hot glue Goo aesthetic I have going on with this patch board. Working on this layout before refining my all in one glitchers.
Been doing an lunch kit analog glitcher with the Rev 1 Pcbs. It's going to have 2 glitchers inside of it. One a built in camera and the other for a vhs. The two knobs on the left bottom are for signal mixing. The right bottom is button glitches and switch glitches. The Inputs and outputs are on the top. It's going to be awesome once completed.
