Want to make your own? Here's the code:
module arm(){
rotate([-45,0,0]){
cube([20,150,10]);
translate([0,150,0])
cube([20,10,97]);
translate([0,153,90])
rotate([45,0,0])
cube([20,10,30]);
module vesa(){
translate([0,0,0])
cylinder(d=4.5, h=10);
translate([100,0,0])
translate([0,100,0])
translate([100,100,0])
module mount(){
rotate([45,0,0])
union(){
arm();
translate([150,0,0])
arm();
translate([0,0,0])
rotate([-45,0,0])
difference(){
cube([150,120,5]);
translate([35,10,0])
vesa();
module brace(){
union(){
difference(){
cube([13,75,22], center=true);
translate([0,0,1.2])
cube([10.3,102,20], center=true);
translate([5,40,2.3])
cube([20,20,22], center=true);
translate([0,-55,0])
cube([30,30,30],center=true);
translate([15.2,29,0])
cube([20,2,22], center=true);
mount();
rotate([0,0,-90])
translate([-150,110,11])
brace();
rotate([0,0,90])
translate([130,-90,11])
brace();
