got some Hex socket cap head M3 screws. They fit well an sit nicely into the bore of the hole. There is still a bit of material to clear out of the bore, which causes the head of the screw to sit proud but it like it lie that.
A project log for Battery Supply for DSO138 portable Scope
Turning a cheap DSO kit into a cheap automotive scope
