The original plan for this project was to create a fun RC Paddle Boat. However, during the project, I came up with the idea of adding a fish feeder. This means that besides enjoying a ride around the lake, the boat can also be used as a bait board for fishing, and can deliver food and medicine in pellet size needed by fish to otherwise inaccessible areas like Mangrove.
The RC controller and the Boat communicate using the ESP-NOW protocol, eliminating the need for a separate radio controller circuit and reducing the complexity and cost of the construction. In my test, I achieved a range of around 200m (line of sight). Additionally, the boat stays afloat with the help of two water bottles.
I also build an RC controller for this. you can control the movement of the boat using a single joystick also you can drop the payload by pressing the pushbutton on top of the joystick. you do not need any pairing for RX and TX it will done automatically. you can switch on the TX by pressing the push button on the side. You can also see the battery indicator on the top. TX is rechargeable through USBC
Supplies
Supplies
Receiver parts
  1. 8*M3 x 10mm
  2. 4*m3 x15mm
  3. 12* M3 nut
  4. 4*m4 x10mm
  5. 4*m4 x nut
  6. 2*18650 Battery 2500mah
  7. 2*To pin JST XH connectors male and female (2.54MM PITCH)
  8. MT3608 voltage booster
  9. BMS 5v booster
  10. 360-degree servo
  11. 4*M4 6mm Knurled Threaded Insert
  12. DRV8833 motor driver
  13. Seeed Studio XIAO ESP32C3
  14. 2*300 RPM L-Shape BO Motor (couldn't find international shipping )
  15. 2.4ghz antenna
  16. 2*water bottles
  17. Heat Shrink Tubing kit
Transmitter parts
  1. 18650 Battery 2500mah
  2. Push button
  4. BMS 5v booster
  5. 2.4ghz antenna
  6. 4 axis joystick
We are not using ordinary servo motors for this project. We need a 360-degree servo for this build. Currently, I'm using a modified 90° servo. This video helped me learn how to mod it. However, there's no need to modify the 360-degree servo; it is available in the market. I have attached a link to it in the part list.
For this project, I used a 1L water bottle with a 3-inch diameter. If you can't find one like this, you can also use a PVC pipe with both ends closed. A simple redesign of the floater holder will enable you to adapt this build to any other size of similar-looking water bottles.
Step 1: Designing in Fusion 360
RX
TX
This project is built around the water bottle. Design is broken down into several levels for easy 3d printing.
Step 2: 3D Printing
3D Printing
I designed the object in parts due to its complex nature, so we will need to assemble it after 3D printing. I used orange PLA and grey PLA. 3D printed all models in my anycubic printer. In 0.2mm layer height and 30% infill
Also please note that you had to print several STL files multiple Times
  1. Floater clamp X4
  2. Floater end cap X4
  3. Motor clamp X2
  4. Motor holder X2
  5. Wheel X2
Step 3: Finding MAC Address of Your XIAO ESP32C3
We are using the ESP-NOW protocol for communication between the transmitter (TX) and receiver (RX). For this, the transmitter (TX) needs to know the unique MAC address of the RX ESP32. You will need to run the following code on your ESP32C3 receiver (XIAO) to find its MAC address. After running this program, the MAC address will be displayed on the serial monitor.
My MAC address is 64:E8:33:8A:22:54
Code for finding the MAC address
#include
#include
void readMacAddress(){
uint8_t baseMac[6];
esp_err_t ret = esp_wifi_get_mac(WIFI_IF_STA, baseMac);
if (ret == ESP_OK) {
    Serial.printf("%02x:%02x:%02x:%02x:%02x:%02x\n",
                  baseMac[0], baseMac[1], baseMac[2],
                  baseMac[3], baseMac[4], baseMac[5]);
  } else {
    Serial.println("Failed to read MAC address");
void setup(){
  Serial.begin(115200);
  WiFi.mode(WIFI_STA);
  WiFi.STA.begin();
  Serial.print("[DEFAULT] ESP32 Board MAC Address: ");
  readMacAddress();
void loop(){
Step 4: Flashing Program the Code
Before uplodring the code we need to enter the MAC address of the of our receiver which is 64:E8:33:8A:22:54 for me we need to add a 0x before before it ,
Then it will be 0x64,0xE8,0x33,0x8A,0x22,0x54
Put that in this line of the code
// MAC address of the receiver
uint8_t receiverAddress[] = {0x64, 0xE8, 0x33, 0x8A, 0x22, 0x54};
Here is the full code for the TX
#include<Arduino.h>
#include<esp_now.h>
#include<WiFi.h>
// Define pins for Xiao ESP32C3
#define JOYSTICK_X_PIN 0 // ADC1 channel 1 (GPIO 0)
#define JOYSTICK_Y_PIN 1 // ADC1 channel 2 (GPIO 1)
#define SERVO_BUTTON_PIN 2
// Thresholds for joystick movement
#define JOYSTICK_THRESHOLD 100
// Structure to hold the message data
typedefstructstruct_message {
int xAxis;
int yAxis;
bool servo;
} struct_message;
struct_message message;
voidsetup(){
// Initialize pins
pinMode(JOYSTICK_X_PIN, INPUT);
pinMode(JOYSTICK_Y_PIN, INPUT);
pinMode(SERVO_BUTTON_PIN, INPUT_PULLUP);
// Initialize WiFi in station mode
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
        Serial.println("Error initializing ESP-NOW");
return;
// Register peer
esp_now_peer_info_t peerInfo;
memcpy(peerInfo.peer_addr, receiverAddress, 6);
    peerInfo.channel = 0;
    peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
        Serial.println("Failed to add peer");
return;
voidloop(){
// Read joystick values
int xValue = analogRead(JOYSTICK_X_PIN);
int yValue = analogRead(JOYSTICK_Y_PIN);
// Check for significant movement
    message.xAxis = (abs(xValue - 2048) > JOYSTICK_THRESHOLD) ? xValue : 2048;
    message.yAxis = (abs(yValue - 2048) > JOYSTICK_THRESHOLD) ? yValue : 2048;
// Read button state
    message.servo = !digitalRead(SERVO_BUTTON_PIN);
// Send message via ESP-NOW
esp_now_send(receiverAddress, (uint8_t *)&message, sizeof(message));
// Short delay
delay(100);
 RX code
#include<Arduino.h>
#include<esp_now.h>
#include<WiFi.h>
#include<ESP32Servo.h>
// Motor driver pins
#define MOTOR_A1 2
#define MOTOR_A2 3
#define MOTOR_B1 4
#define MOTOR_B2 5
// Servo pin
#define SERVO_PIN 6
Servo myServo;
int xAxis;
int yAxis;
bool servo;
} struct_message;
voidmoveForward(){
digitalWrite(MOTOR_A1, HIGH);
digitalWrite(MOTOR_A2, LOW);
digitalWrite(MOTOR_B1, HIGH);
digitalWrite(MOTOR_B2, LOW);
voidmoveBackward(){
digitalWrite(MOTOR_A1, LOW);
digitalWrite(MOTOR_A2, HIGH);
digitalWrite(MOTOR_B1, LOW);
digitalWrite(MOTOR_B2, HIGH);
voidturnLeft(){
voidturnRight(){
voidstopMoving(){
// Callback function to receive data
voidOnDataRecv(constesp_now_recv_info_t *recv_info, constuint8_t *incomingData, int len){
memcpy(&message, incomingData, sizeof(message));
voidsetup(){
// Initialize motor driver pins
pinMode(MOTOR_A1, OUTPUT);
pinMode(MOTOR_A2, OUTPUT);
pinMode(MOTOR_B1, OUTPUT);
pinMode(MOTOR_B2, OUTPUT);
// Initialize servo
    myServo.attach(SERVO_PIN);
// Init ESP-NOW
return;
// Register receive callback
esp_now_register_recv_cb(OnDataRecv);
voidloop(){
// Handle movement based on joystick values
if (message.yAxis < 1500) {
moveForward();
    } elseif (message.yAxis > 2500) {
moveBackward();
    } elseif (message.xAxis < 1500) {
turnLeft();
    } elseif (message.xAxis > 2500) {
turnRight();
    } else {
stopMoving();
// Handle servo activation
if (message.servo) {
        myServo.write(90); // Move servo to 90 degrees
    } else {
        myServo.write(0); // Move servo back to 0 degrees
Step 5: Wiring Diagram of Transmitter and Rover
Wiring diagram of TX
Wiring diagram of RX
Step 6: Voltage Setting on MT3608
Before assembling we need to preset the voltage on MT3608, if you buy a new module you need to turn the potentiometer around 20 times or more in a counterclockwise position and then once you get the regulated voltage at the output you can use the module. Connect your battery to VIN+ and VIN- and set the voltage to 5v. measure it from the OUT+ and OUT- using a multimeter after that remove the battery input
Step 7: Rover Assembly
7.1
Connect a female JST connector into the input on MT3608. Which needs to be at least 5CM in length make sure the left side of the JST is VIN+ and the right side VIN-
7.2
Glue the XIAO, motor driver and MT3608 into the main body
7.3
Solder and connect all wires between XIAO, motor driver and the MT3608
7.4
Insert the servo into the 3d printed slot and solder the wires into Xiao
7.5
Connect the antenna port into the XIAO and another connecter to the hole on the side wall. thigh it using a nose plier
7.6
Connect the screw to the servo shaft and secure it with a screw holder. Attach the screw holder using super glue.
7.7
Install the M4 nut insert using a soldering iron into the 3d printer hole
Do the same thing in all 3 positions
7.8
Glue the holder into the top cap
7.9
Insert the two rings into the bottle and partially tighten it with an M3 X 10mm screw, because we need to be able to move it later.
7.10
Screw in the main body, frame and the right using M3 x 15mm bolt and nut
Do the same thing on the other side also
You can tighten the ring using an Allen key.
7.11
Inster the BO motor into the motor holder and fasten it with two M3X10mm Bolts and nuts
Do the same thing on the other side too.
7.12
Twist two cables together, solder them into the motor, and run the wire through a side hole. Seal the hole with hot glue.
Do the same thing in the other side to
We just completed the main circuit assembly of the rover
Step 8: Battery Pack
As you know we just completed the wiring of the rover but now we need to power source. for that, we are going to build a battery pack. It is a 1S 2p pack
8.1
Solder two battery is in parallel with wires
8.2
Run a male JST connector to the battery cap
8.3
Cut and Solder these JST wires into the battery back +ve and -ve
8.4
Insert the battery pack into the battery holder close the cap and glue the battery cap
You can recharge this battery pack using any 1S BMS just solder a JST connector to it
Also, you can connect the battery pack to the rover using this JST connector
Step 9: Final Rover Assembly
9.1
Install the wheels into to motor shaft. I used the screw that ships with the BO motor
9.2
Install the top cap with the M4 bolts, you can remove it to access the battery
9.3
Connect the receiver antenna
9.4
Install the 3d printed cups into bottles
9.5
You can use the payload cap to close the payload holder after filling it
Step 10: Transmitter Assembly
10.1
Install the joystick into the transmitter's main body
Make sure that the joystick orientation is similar to this image
10.1
Cut 2 terminals of the push button place it into the3d printed slote and glue it
10.2
Solder 2 wires to the 18650 batteries
10.3
Glue the battery in the slot and complete the wiring according to the wiring diagram . the BMS module and XIAO is installed using glue
also, you can use 2 yellow wires for the push button of the joystick, we don't need the rest of the wires
10.4
Connect the TX antenna in Xiao
Install the antenna port on the top side hole
10.5
Close the TX enclosure using the back cap. secure the back cap with some glue
We just completed the assembly of the TX
Step 11: Test
We have finished build so now it's time to test it. You can load any pellet-sized food or medicine into the payload holder and close it with the top cap. During my initial test, I found that when I placed it in water, it was not balanced. So, you will need to loosen the floater clamp and adjust both of the water ballasts to achieve good overall balance
