So I spent the last couple of days with calipers, rulers, and protractors measuring and modelling the Trekulator case. I really enjoy this kind of work. I find it to be challenging and relaxing at the same time. I helps when the end result turns out pretty good.
I'm on the lookout for a better color match but the case is pretty much done.
