🌟 About the Project
The nRFBOX Project is an open-source initiative aimed at providing a comprehensive set of tools to explore the 2.4GHz spectrum, including Bluetooth and other wireless protocols. Built around the powerful ESP32 Wroom32U microcontroller, the project incorporates multiple NRF24 modules, an OLED display, and several other components, enabling users to perform spectrum analysis, jamming, spoofing, and more.
Whether you are a beginner looking to learn about wireless communication or a professional seeking a customizable toolkit for advanced tasks, this project offers a perfect blend of features, flexibility, and functionality.
🎯 Features
The nRFBOX comes packed with a variety of features, making it a powerful tool for wireless experimentation and security testing:
Software Features
- Dynamic Channel Scanning: Continuously monitors the 2.4GHz frequency band to identify active devices and channels.
- Signal Analysis: Provides detailed insights into detected signals, including signal strength and data rate, helping in identifying potential interference sources or security threats.
- Multi-Mode Jamming: Supports multiple jamming modes, such as constant, random, and selective jamming, allowing for a range of security tests.
- BLE Device Emulation: Simulates BLE devices to test the security responses of real devices in a controlled environment.
- User-Friendly Interface: Features a menu-driven UI displayed on the OLED screen for easy navigation between different modes and settings.
Hardware Features
- ESP32 Wroom32U: The main controller provides dual-core processing, integrated Wi-Fi, and Bluetooth capabilities.
- NRF24 GTmini Modules: Essential for 2.4GHz communication and jamming; three modules are recommended for advanced BLE jamming functionalities.
- 0.96" OLED Display: A small yet high-contrast display for visual feedback and interface navigation.
- LF33 Voltage Regulator: Ensures a stable 3.3V output to power the microcontroller and other sensitive components.
- CP2102 USB-to-Serial Converter: Facilitates easy programming and debugging through USB.
- TP4056 Li-Ion Charging Module: Manages charging of the onboard Li-Po battery, including protection against overcharging.
- WS2812 Neopixel: A single RGB LED acting as a status indicator for various modes and states.
- Antenna Connector: Enhances signal strength and range for effective communication and jamming.
- Micro Switch: Provides tactile input for mode selection and user commands.
🎯 Core Functions
1. Scanner
The scanner continuously sweeps across the 2.4GHz band, identifying active channels and devices. This function is crucial for identifying potential sources of interference or threats in a given area.
2. Analyzer
The analyzer provides a deeper dive into the detected signals, offering data on signal strength, modulation, and data rates. It helps users understand the wireless environment more thoroughly.
3. Jammer
The jammer function disrupts communications on specified channels. It offers various modes, including constant, random, and selective jamming, making it useful for security testing and research.
4. BLE Jammer
Specialized in targeting BLE devices, this function disrupts Bluetooth communications within a certain range. It is most effective when using three NRF24 modules simultaneously.
5. BLE Spoofer
Simulates BLE devices to test security responses or to create controlled environments for BLE testing.
6. Sour Apple
A specialized protocol attack designed to test vulnerabilities in wireless network setups, particularly targeting specific communication protocols.
🧰 Getting Started
Step 1: Gather Your Components
To build the Wireless Toolkit, you will need the following components:
- ESP32 Wroom32U
- NRF24 GTmini Modules (x3 for advanced BLE jamming)
- WS2812 Neopixel
- Micro Switches
- Antenna Connector
CiferTech
