Hardware Features
- Atmel® SAMD21E18A
- ARM® Cortex®-M0+ based MCU running up to 48MHz
- 256KB embedded Flash and 32KB SRAM
- Low power consumption at <70µA/MHz
- DMA and Event system
- Four flexible serial communication modules (SERCOM)
- Full-Speed USB Device and embedded Host
- 10 Channels of 12-bit ADC ; 10-bit DAC
- Hardware touch support
- Micro-USB Connector
- ESD Protection up to 5kV on USB+ and USB-
- USB connector shield RC Filter
- MCP1700 3.3V LDO Power
- Extremely Low Operating Current for Longer Battery Life (1.6 uA typical)
- Very Low Dropout Voltage (178 mV at full load)
- Rated 250mA Output Current
- High Output Voltage Accuracy (±0.4% typical)
- Over-Current and Over-Temperature Protection
- 32.768kHz Crystal
- 32-Bit Real Time Clock and Calendar
- Built in 4.7kOhm resistors for I2C interface
- Built in Arduino LED
- PIN_LED
- PIN_BUILTIN
- Built in WS2812B RGB LED
- Uses Neopixel Arduino Library
- Self-Contained Driver/RGB LED
- Only requires one Arduino PIN
- Built in RESET Button
- Pulled up to stop unintended reset
- Discharge safety circuitry / filtering capacitor
- Built in user Button
- ACTIVE High
- Debounce Circuitry
- Cortex Debug Header (10-Pin)
- Device programming and debugging
- 22 PINs on 2 protoboard spaced (0.1″) headers
- USB SAM-BA (CDC) bootloader
- Arduino Bootloader
- Arduino 1.6.5+ Compatible
- LEGO Minifigure Shaped board
- Approximately 0.95×1.55 inches (24.21×39.32 mm)
- 4-Layer, High Quality PCB
Benjamin Shockley
Very cute pcb. If you do a respins, the eyes could be little round or square leds (it is a robot after all)if that can be done without looking freaky.
