3D printed 6DOF robot arm controlled with Klipper - introductory robotics
This is my robot. There are many like it, but this one is mine. This robot is my latest obsession. It is the tool I use to push myself to learn new skills. I must master it as I must master my life. Without me, my robot is useless. Without my robot, I am bored. I must use my robot to do cool things. I must share my findings with others for these findings might lead others to the same path, or at least get me some kudos. (Loosely based on the Rifeleman's Creed) | ![]() |
In this series of posts, I'll try to share my experiences in learning through building. Specifically, by building a six-degree-of-freedom (6DOF) manipulator, AKA a robot arm. I'll try to cover everything you need to build your own, share some relevant examples and demonstrate one way of diving into robotics. But first, I'd like to clarify my reasoning.
Why write "yet another robotics tutorial"? Over the years I made many attempts at getting through an introductory robotics text book. The first attempt was given up on quite early, retaining little beyond some basic definitions. On successive attempts I had little more success. A promising new book or tutorial might catch my eye, I'd spend a few weeks working through example problems and inevitably giving up yet again. Not only did the maths seem impenetrable, the goal of "doing cool stuff™" was nowhere in sight.
Not wanting to spend hard earned cash on yet another hobby that ends up collecting dust in a cupboard, I decided on a foolproof test. "If you get through one of those books" said I, "that means you're into the hobby enough to put money on it". As should be clear from the above paragraph, no such luck. The urge to play around with robots never left, and scaling the mountain of introductory robotics never seemed any more achievable.
Thankfully, my wife resolved the conflict with a simple question: "How about we buy a 3D printer? I heard they're getting cheap". Agreeing excitedly, I immediately knew the answer to her next question: "What will you build with it?". "A robot" was my response.
Some time later, we're doing a sanity check with a relatively functional arm. We were trying to make the arm follow a specific path and return to it's initial position, but couldn't get it right. Making the arm to return to an initial position was straightforward, but tracing out a path just didn't seem to work. In hindsight, why would it? I was doing it all wrong.
"Maybe all those matrices are actually good for something?" I wondered, uncertain.
Since then, I've become a close personal acquaintance with a variety of matrices, even of the rotational and homogeneous persuasion. Similarly, quaternions no longer seem so malicious nor are reference frames a confusing jumble of notation & convention. There's still a lot to learn, but failing at controlling a physical robot arm helped me get over the hump of jargon and start seeing the forest through the trees.
Whether you're a robotics enthusiast, a maker looking to expand your skills, or simply curious about the concepts behind robotic arms, these posts might have something for you. Join me as we delve into my attempt to scratch a robotics itch using open source software.
It seems my plan to avoid spending money has failed. I was now in the hole for a 3D printer and who knows how much filament. When it rains, it pours and little did I know how many more purchases were in my future. At that point, being comfortable with spending actual cash, my design considerations changed somewhat. Specifically, since I was now getting access to a limitless variety of plastic parts, I felt it was important to have them make up as much of the robot as possible.
Hopping on Thingyverse (and a few others), I started searching for a robot arm. Although the community created some extremely, creative, models, nothing clicked. I didn't like the look of them, you might say. Eventually, somewhat...
