Latest update : 15/09/2024
A project log for Botje, Interactive Arduino R4 WiFi Companion
R4 WiFi collection of what I found on the net throwed together with some stuff from me in an interactive companion.
wils-nicowils Nico 09/15/2024 at 16:590 Comments
Last update is a major update with many changes.
System now runs mainly on RTC clock and when network, sync every 30 minutes the RTC with pool.
Offline, RTC is used and you can change this RTC time manually.
All internet applications: jokes, open-meteo and internet date/time are offline blocked.
All games are now together in a vertical menu that is called up with Joystick Button.
Joystick Button is also used for selection in games menu and games.
Joystick Button is also used to rise flappy in play.
Other buttons (From left to right) :
Button 1: Temperature and humidity.
Button 2: UV index and air pressure.
Button 3: Air Quality and Open-Meteo.com .
Button 4: Internet date/time and manual RTC set .
.Selected button is also used in menu to perform menu selection.
MQ sensors menu is vertical, use joystick up/down to choose the right sensor that is plugged in.
Manual RTC setting buttons:
Button 4;Selection hour, minutes, seconds.
Button 1: Change value of hour, minutes or set the seconds to zero.
Button 2: Saving set time on RTC.
Button 3: Leave manual time settings without saving on RTC.
