Hackaday.io Hackaday.io
Sign up Log in
MonkeyDo
A project to learn about HTML, Websockets, electrical control systems and embedded networking.
ehughesehughes
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1.9k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
186
0
1.9k
8
Team (1)
  • ehughesehughes
Join this project's team
  • Repo for Javascript, etc
  • mbed Firmware
  • Youtube Videos
  • Main Landing Page
Related lists
Freedom Development Board Projects
ARM M0+/M4 Micros and expansion boards built to Arduinoâ„¢ shield specs.
Freescale Sensor Projects
Accelerometers, gyros and magnetometers with sensor fusion software to bring it all together.
Freescale Parts
Projects using Freescale hardware
Embedded Network Skillz
Ways to utilize sensors, software to connect
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 07/20/2014 and last updated 5 years ago.
Description
In this project, you will learn how to do basic electrical automation and control via the web. Think of the NEST.... only more open and hackable! Using Websockets, Javascipt and HTML5, you will have a simple way of viewing remote data and be able to control some solid state relays. This framework will allow you to create more complex IoT applications. The example will combine a FRDM-K64F and a FRDM-AUTO to read a temperature sensor and control a solid state relay.
Everything is open, hackable and extensible!
Here is the main page with instruction videos, links to schematics, etc.
https://community.freescale.com/docs/DOC-101449
Project Logs
Collapse
  • Adding a Project
    ehughes • 07/20/2014 at 20:49 • 0 comments
    Welcome!    I have just added the MonkeyDo Project to hackaday.io
    See the main page on Freescale's community.
    Enjoy!
View project log
Log In/Sign up to comment
Sign up with Github
OR
The Bee Comfy is a MCU-based climate control system for honeybees
Project Owner Contributor
Bee Cage Climate Control
criptastichackerCriptasticHacker
This is a home automation system that uses C#, Arduino and OpenCV to facial recognition.
Home automation system with facial recognition
sircloverSirClover
This is an update of the previous project "XBee and FPV cam spy car". This allows me to control the car over the internet.
Internet and FPV cam spy car
hubacekphubacekp
Hackaday Prize 2020
RT-Thread Community DIY Project
DIY A MecaNum Wheel Car with Phone Remote Control.
rt-thread-iot-osRT-Thread IoT OS
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MonkeyDo", please tell us the reason.
Send message
Remove Member
