The keyboard can be cut off and connected via a 12-pin connector. There are two options for the keyboard cover. One possibility for 3d printing lovers is to enable the installation in the PCB box, but this will require a few more attempts. 18650 battery optional, there will be enough space in the box for any battery.
BOM: required components if you order bare PCB only
- 1x this magic motherboard PCB with optional covers
- 1x Heltec TRACKER order link package contains everything needed (battery connector, antenna with SMA, male headers)
- 1x piezo beeper
- 4x female headers
- 1x power switch
- 36 tactile switch recommended with switch force 1N 7mm height if you want use cover or smaller if you use motherboard only
- 2x optional side buttons to easier access to USER or RESET button
- 1x optional 18650 battery holder
DIY Assembly
- solder switches
- solder Heltec tacker female headers to board
- upload firmware with WebFlasher
Meshtastic firmware
- firmware is ready in Meshtastic Flasher select TrackSenger
bobricius
sayanee
Steph
CYUL
