Well, last week after a lot of time spend in research i decide to use the CH32V303 microcontroller from the chinese manufacture WCH, mostly because it's price. but after read after read the documentation and start some PCB routing i discovered that CH32V303 has 4 versions [1}, 3 with 16 TouchKey pins and only one with 10:
And for the surprise of no one the version that i initially choose for this project was the one with only 10 touch capable pins, util there everything was "ok" i only had to pick the version with more pins... but checking the price it turns out the CH32V303RBT6 is at least 50% more expansive than CH32V303CBT6 in quantity:
I really wanna this project been cheaper as possible. So i had no other option than start to search for microcontrollers again. So i spend some hours looking for Silver.. than a i found Gold; The CH582M:
Here's the actual drawing:
