Its alive!
A project log for The Jolly Tagger SAO
Its a NFC Tag, a Keychain pendant, a pin and a blinky Jolly Wrencher in ONE SAO !
phil-weaselPhil Weasel 10/05/2024 at 16:530 Comments
So after testing the first version i just soldered the bare minimum to the ENIG version and .....
It actually works!
Double checking the inductance we are around 4.7 - 4.8µH on both versions but appearently still close enough. Also my fear that the "faceplate" will block too much turned out positive.
LED´s will be tested next week.
