Possibly Paper Concertina para foil with stiffer sections for elevators. Weight and control using this method may still be an issue and this could increase size. Idea: Use v thin plastic coated card folded. Like a paper aeroplane. Or standard smaller Nylon envelope which folds out along slightly stiff thin plastic folded rods. Again weight and balance could cause issues with this.
