I put out every thing you need to rebuild this project. There is still a couple of things I want to do, but for now, Im gonna set it aside and test it out.
Further Work:
- Make a PCB that is small enough to fit into the cassette player
- Have the RP2040 save the tuning
- Implement more midi commands (pitch bend, reverse direction...)
- Get rid of the PWM square wave
- Use other channels
- Release source code
decurus
