@davedarko had a great idea to just tape off the screen bar and hit it with spray paint. That is far much less work than cutting vinyl. I tried that and it worked great. I just need to use fresh tape so I don't get the bleed through on the edge. I think it collects dust on the edges and then allows paint to wick under. Regardless, this will be my solution. I used some semi-gloss black Rustoleum spray paint.
Thanks for the great simple idea Dave!
I see a white bar and I want it painted black... [guitar background music]
apparently, if you hit it with a clear coat first, then the cracks get filled in clear and then the black on top is much cleaner. I always remember this _after_ spraying something, so I can't tell how good it works.
but this feels like a viable way for having an easy two tone silscreen thing going
I'll be trying this ASAP! Thank you!
