Sticky Situation
A project log for SAO Speak and Spell
First PCB board design and SAO in one project motivated by Supercon 2024
jeremygeppertjeremy.geppert 10/30/2024 at 22:430 Comments
I came home today to find all the touch up painting completed. Thanks G! Time to glue the speakers on each unit. I used CA glue. Should be good? Seems solid and on the one I tested it sounded good. That is after letting the smoke out of an amp board. 5v some how found itself on the ground. Pffffft.
The solder and pads don't show up unless in bright direct light.
