ESP32 Weather Station
Based on an ESP32 PCB, with ESPhome
Public Chat
Based on an ESP32 PCB (https://fr.aliexpress.com/item/1005001676660492.html), with ESPhome and compatible with aliexpress weather station sensors (https://fr.aliexpress.com/item/1214985366.html) and modified added feature.
The base is an esp32 and a replacement kit for weather station.
I removed the 433MHz electronic and replace by some 12c sensors (lux, temperature, humidity, pressure)
Now the ESP32 PCB is developped, the corrected (but not tested) version is V1.1. With RJ12 connectors
No i2c Sensors PCB is developped.
Schematic and gerbers,... arrives as soon as all works,if needed I can shake the schematic as actual version
JPEG Image - 1.37 MB - 10/22/2024 at 10:14
Preview
PCB SMH-2022 V1.1.pdf
Adobe Portable Document Format - 210.11 kB - 10/19/2024 at 15:22
Preview
Schematic SMH-2022 V1.1.pdf
Adobe Portable Document Format - 110.87 kB - 10/19/2024 at 15:22
Preview
Schematic Sensors SMH-2022 V1.1.pdf
Adobe Portable Document Format - 97.35 kB - 10/19/2024 at 15:22
Preview
PCB Sensors SMH-2022.pdf
Adobe Portable Document Format - 90.77 kB - 10/19/2024 at 15:22
Preview
View all 7 files
