ADisplay
Arduino Display, a oled directly connected to an arduino on the board
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
So basically, i wanted to see if i could remove the need for that pcb board that the hobbyist Oled 64x64 has cause it looks a bit goofy to me.
Here is the ADisplay! with a built in bluetooth HC-05 this board can display what you need when you need.
Need a watch?
Need to test animations?
Need a serial monitor for BLE devices?
Then the ADisplay is the hobby board for you!
