Added a guide channel prototype. The guide channel is highly experimental and is currently only included in the main branch for testing. Documentation and hardening of this module is ongoing - use at your own risk :) Currently, video playback is in progress.
![](https://cdn.hackaday.io/images/1759141734899586290.png)
Copy `guide.json` from `confs/examples/` into `confs`
cp confs/examples/guide.json confs/
The example configuration provides the minimum configuration to enable the guide channel with the default view.
{"station_conf" : {
"network_name" : "Guide",
"network_type" : "guide",
"channel_number": 3,
"runtime_dir" : "runtime/guide",
"content_dir" : "catalog/indie42_catalog/commercial/December"
The guide channel's appearance is controlled through a set of parameters. The default parameters can be overridden. To override a parameter, just put it into the configuration file with the new value. The following parameters (shown with their default values) are available:
"width" : 720,
"height": 480,
"top_bg" : "blue3",
"bottom_bg" : "blue4",
"pad" : 10,
"messages" : ["Hello FieldStation42\nGuide preview", "Cheers!\nFrom us to you!", "FieldStation42 Guide\nOn cable mode."],
"message_rotation_rate" : 10,
"message_fg" : "white",
"message_font_family" : "Arial", "message_font_size" : 25,
"network_font_family" : "Arial",
"network_font_size" : 12,
"schedule_font_family" : "Arial",
"schedule_font_size" : 12,
"schedule_highlight_fg" : "yellow",
"schedule_fg" : "white",
"schedule_border_width" : 4,
"schedule_border_relief" : "raised",
"footer_messages" : ["You are watching FieldStation42", "Now with cable mode."],
"footer_height" : 50,
"schedule_row_count" : 3
See the github repo for more details.
