After some help from my brother once again there is now a red power light. It's a tiny board and getting a bit crowded. I submitted an order for a bunch of boards tonight after verifying everything 10 times.
Ordering resistors and leds from DigiKey next. They are SMD, this will be fun. The through hole effect for the LED should be worth it though.
Don't worry!!! This isn't a repeat mistake like on my first SAO Speak & Spell boards... The pins on the LoRa module get trimmed and the whole thing slides down during assembly,
I found the print mirrored image in KiCad for alignment purposes when you pads are on the back of the pcb.
