Revision 1.0 : 1/1/2017 Tested and Working Correctly.
Notes: Since the maximum sampling frequency of the ADS1115 is 860Hz, the input anti-aliasing filter is set for 860Hz/2 or around 430Hz. Most ADS1115 breakout boards DON'T include any input conditioning or filtering, but we include in a simple single pole, low pass filter on the four (4) Grove input Jacks.
Pattern Agents
