I use low pressure air to both drive and control a solar cooker reflector and a solar panel. They are on equatorial mount so only simple rotation is required. I wish to make the components, especially the valve that controls the speed of the waterwheel, smaller and to make some of them electronic. If someone wanted to make a 3d printed version of the waterwheel, that would be cool but not necessary.
