• Project Terminology and the First Prototype Part
    Andrei Gramakov • 12/08/2024 at 20:13 • 0 comments
    This week, I finalized the project terminology. Now, the most important parts that define the framework are called Base Parts. Using the base parts, everybody can create Prototypes - the reusable parts with particular purpose. The projects are supposed to be assembled using Base and Prototype parts. If a part is modified and has low potential of reusability, such a part is called a Custom Part.
    Also, added the first prototype for robots with two motorized wheels
    You can find the prototype used in one of the documentation pictures (the project itself will be later)
    The updates are already in the repo:
  • Framework Features + Update v1.1
    Andrei Gramakov • 11/09/2024 at 23:19 • 0 comments
    With the new release v1.1 I've added shells. Now your project can be protected from physical impact. For the updates for to the repository: https://github.com/an-dr/simpleR .
    Also, I've spent some time explaining in detail all the features of the framework. Here they are (copy-paste from the repo)
    Small Range of Parts
    The framework is based on a small range of parts that can be easily combined to create a wide range of projects.
    See: Base Framework Parts
    Scalable
    Choose the project of the size you need, and extend it in the future.
    s1s2s3
    Flexible
    Adjust the project to your needs. Add or remove platforms, choose the right volume for you components.
    f1f2
    Easily Printable
    All parts are designed for easy 3D printing. No supports are needed.
    p1p2p3
    Rigid
    The special shape of the bars makes the structure stable and rigid in all directions. The shells provide additional structural support.
    r1
    Modifiable
    All parts are designed for easy modification. They are shipped in STEP format, which can be opened in any CAD software.
    m1➡️m2
    m3➡️m4
    Embeddable Nuts
    The nuts are accessible and reliable alternative to metal inserts than provide a strong and reusable connection between the parts.
    n1n2
    Modular
    All the parts are made in the way so you don't have to re-print large volumes of plastic when you want to make a small change. Reprint only necessary parts.
    mo1mo2mo3
  • Project Repository
    Andrei Gramakov • 11/04/2024 at 22:33 • 0 comments
    Hello! Just finished with the project repository, will update it with every framework release. So far it is version 1.0
    Link: https://github.com/an-dr/simpleR
  • Universal Level Part for Better Scalability
    Andrei Gramakov • 10/27/2024 at 13:55 • 0 comments
    I was not fully satisfied with my design for 2+ levels.
    It has 3 flaws:
    1. The middle level part is different with the others → it can be used only in 2+ configuration
    2. The vertical mounts are significantly different for each configuration: 1, 2, 2+
    3. While the bending of the construction perpendicularly the vertical mounts resist the bend, bending along the vertical mounts depends on the printing precision and might allow the levels to dance left and right.
    Here how I finally solved all these problems
  • Fitting and Wrapping
    Andrei Gramakov • 10/21/2024 at 21:02 • 0 comments
    Experiments with the LeOn v2 showed that having the same universal connector for both internal and external structures is not ideal. If there is no perfect fit between the cover, and internals it cases wrapping of the shell
  • Scaled Prototype
    Andrei Gramakov • 10/21/2024 at 17:09 • 0 comments
  • Cat toy using simpleR
    Andrei Gramakov • 10/14/2024 at 19:43 • 0 comments
  • LeOn robot, but simpleR
    Andrei Gramakov • 10/07/2024 at 21:40 • 0 comments
    Here is the reimplementation of my robot LeOn, using the simpleR framework. Will add details and when it is fully ready
  • Iteration 2
    Andrei Gramakov • 10/01/2024 at 18:45 • 0 comments
    Also considering reimplementing my other projects using the framework....
