This week, I finalized the project terminology. Now, the most important parts that define the framework are called Base Parts. Using the base parts, everybody can create Prototypes - the reusable parts with particular purpose. The projects are supposed to be assembled using Base and Prototype parts. If a part is modified and has low potential of reusability, such a part is called a Custom Part.
![](https://cdn.hackaday.io/images/1004861733688700963.png)
Also, added the first prototype for robots with two motorized wheels
![](https://cdn.hackaday.io/images/214941733688767476.png)
You can find the prototype used in one of the documentation pictures (the project itself will be later)
![](https://cdn.hackaday.io/images/4973251733688894191.jpg)
The updates are already in the repo:
