Notes on MIDI Interface Hardware Development
A project log for MIDI Interface for RC2014
Building MIDI Interface for RC2014. The goal of this project is to build a music system with RC2014 computer and external (legacy) MIDI box
morecatlabmorecat_lab 10/03/2024 at 10:400 Comments
In June 2024, I completed the hardware for a MIDI interface, but I hadn’t yet documented the process. This blog post will serve as a reference for the design and technical details.
1. Design Approach
Since this was a prototype, I focused on building it quickly by leveraging existing components and minimizing effort. The interface was assembled using the following components:
 (1) An ACIA interface board for the RC2014 bus
 (2) A MIDI clock generator
 (3) A 5mA current loop interface for MIDI
2. Technical Details
(1) ACIA Interface Board for RC2014 Bus
To expand Steve Cousins' SC114 (Z80 Motherboard), I had already created the "61c Serial and Storage board", designed by Karlab, which can be found at (https://oshwlab.com/karlab/61c-serial-and-storage). Since I had a spare board, I decided to make use of it. I just used only the ACIA section, though.
The ACIA can be mapped to the I/O addresses of $80, $90, $A0, or $B0. Since $80 is reserved for the console, I utilized one of the remaining addresses. Additionally, it seems that the Small Computer Monitor (SCM) supports configuration of a second serial port at $A0. In SCM, ACIA is initialized at boot.
(2) MIDI Clock Generator
Generating the required 31,250bps MIDI speed necessitates a 2MHz clock, which cannot be derived from the CPU clock. Fortunately, the board design included a crystal oscillator pattern. While purchasing a 2MHz crystal oscillator would be the easiest solution, I repurposed an AVR TINY202 clock oscillator from a previous project. You can check out the code for that (https://github.com/kuwatay/6809ctrl/blob/main/hardware/6809E-CLOCK/6809E-CLOCK/6809E-CLOCK.ino).
MIDI requires a clock accuracy of ±1%, but using the factory calibration of the TINY202 gives an accuracy of about ±2%. So far, I haven’t encountered any issues, but I plan to replace it with a 2MHz crystal oscillator if needed.
(3) 5mA Current Loop Interface for MIDI
Initially, I intended to use a SparkFun MIDI Shield that I had on hand. However, the shield is designed for Arduino, and its MIDI-OUT circuit connects directly to the pins, making it incompatible with the HD63B50. As a result, I had to design a new MIDI interface with an integrated driver. To keep the design compact, I used a TC7W34 3-channel driver(Triple Non-Inverter) .
TC7W34 is one of my favorite IC, as it is very compact and useful for applications like this. A small SSOP-DIP adapter board makes TC7W34 into 8pin DIP size. For Photo-coupler,  I used good old PC910 made by Sharp, which was obsolete long ago.
Current loop interface for MIDI
Schematic of current loop interface for MIDI.
My favorite TC7W34
Test failed with Sparkfun MIDI breakout board.
