Creating GPTs of Z80 Specialist
1. Motivation
Large Language Models (LLMs), such as ChatGPT, generate programs based on information available on the internet, utilizing language models. For example, if you request it to create a "Hello World" program for CP/M, it will generate a reasonably functional program.
ORG 100h ; CP/M programs start at 100h
LD DE, message ; Load the address of the message into DE
LD C, 9 ; BDOS function 9 (print string)
CALL 5 ; Call BDOS
RET ; Return to CP/M
message:
DB 'Hello, World!$' ; Message to print, ending with a '$'
However, since LLMs do not possess specialized knowledge, if you ask them to create a "Hello World" using the SCM API, the generated program may look somewhat suspicious.
ORG 100h ; Start of the program
LD HL, message ; Load address of the message into HL
print_loop:
LD A, (HL) ; Load the current character into A
CP 0 ; Check if it's the null terminator (0x00)
JP Z, end ; If zero, end the program
CALL 0005h ; Call SCM routine to print a character
INC HL ; Move to the next character in the string
JP print_loop ; Repeat the loop
end:
RET ; Return to monitor
message:
DB 'Hello, World!', 0 ; Message string terminated by 0x00
This happens because the model is relying on general knowledge to generate its answers. By using specialized knowledge, we could likely obtain more refined results.
2. Programming Assistant for Small Computer Monitor (Z80)
To emphasize specialized knowledge and obtain better answers, I decided to create a custom GPT. GPTs can change the policy for generating responses. In this case, I instructed it to refer to the SCM reference manual and user manual when creating programs.
The prompt I provided was as follows:
This GPT is designed to be a programming assistant for working with Z80, an 8-bit microprocessor commonly used in vintage computing and embedded systems. It helps users write, debug, and optimize assembly code for small computer monitors or other Z80-based systems. It will refer SCM user guide and reference manual in knowledge area. It offer practical tips, explanations, and sample code, adapting to the user's knowledge level. The assistant stays focused on Z80 programming tasks, providing guidance on registers, memory management, instruction sets, and general programming flow in Z80 assembly. It ensures clarity in all interactions while avoiding unnecessary jargon.
As intended, it successfully created a program using the SCM API.
ORG 0x8000 ; Start the program at 0x8000 (example address)
LD HL, message ; Load the address of the message into HL
print_loop:
LD A, (HL) ; Load the current character into register A
CP '$' ; Check if the character is the string terminator ('$')
JR Z, end_print ; If the character is '$', jump to end the print loop
CALL api_print_char ; Call the SCM API function to print the character
JR print_loop ; Repeat the loop for the next character
end_print:
CALL api_newline ; Print a new line using SCM API
RET ; Return to SCM
message:
DB 'Hello, World!$' ; Message string terminated with '$'
; SCM API calls
api_print_char:
LD C, 2 ; SCM API function $02: output character
CALL 0x0030 ; SCM API handler
RET
api_newline:
LD C, 7 ; SCM API function $07: output newline
RET
RTS $30 is batter for API call.
You can access the prototype GPTs from here.
morecat_lab
