- The 3 i made indoors, with a LOT of LED panels, it did not succeed, no matter the substrate, oxygenation, or water pump I tried.
- The only one i put outdoors, no matter the substrate, oxygenation, or water pump, it did great.
A bit sad for an “indoor grow” experiment, but it turns out natural light is mostly the only thing that matters x)
Of course, I will try again in 2026 🤞
Tanguy
