1st Thing: I want to emphasize how much my understanding of electronics changed throughout the course of this project. Even so, there are still many design flaws that have not been addressed. Keep this is mind
![](https://cdn.hackaday.io/images/8782051728248156791.png)
![](https://cdn.hackaday.io/images/9416171728248411179.jpeg)
Basic Outline: The watch is a base plate with a circuit board glued on top and a screen soldered above the circuit. An antennae as well as a heart rate sensor is glued on the bottom of this base. The wrist band is sewn onto the base. For the GPS module and the battery, an extra piece of fabric was used to make a sleeve for them on the bottom of a portion of the watch band near the circuit board. Not perfect, but, given the space and price restraints, it is functional and the flaws are almost unnoticeable when worn. Surprisingly, it is pretty comfortable, given that everything is mounted in the right positions. It can be programmed from the pins that protrude from the top of the watch. Idle (with little/no software efficiency code) the watch battery can last most of a day.
![](https://cdn.hackaday.io/images/1206801728248648511.png)
Design Flaws:
-Software is not completed: both bluetooth and WiFi have not been tested or confirmed fully functional
-Pretty difficult to solder and wire up
-BATTERY REGULATION DOES NOT FULLY FUNCTION: This is the deal breaker. Other than the lipo protection circuit within the battery, low voltage protection worked poorly on the watch. Supposably, the voltage divider present in the design was supposed to trigger the ESP to go into a deep sleep state, drawing almost no battery, when it detected a low enough voltage; however, the AMS1117 I used in the circuit would stop functioning and bring the ESP into a reboot cycle before it was able to turn it self off. This must be addressed before this watch can be used past prototyping.
