Pulley Downgearing Tweaks to Design and Rebuild Progress
A project log for My Advanced Realistic Humanoid Robots Project
Building bio inspired realistic looking humanoid robots to do chores and sports and stuff.
larryLarry 10/31/2024 at 05:030 Comments
So it turns out that when the forward and reverse directions portions of the thumb tack pulley downgearing system are doing their thing, they won't always have the same mechanical advantage and so will be moving at different speeds. Therefore, I have to treat the forward and reverse pulley systems as entirely separate systems that have to be completely decoupled and handled independently, each pretending like the other one doesn't even exist. They can share the same thumb tack, but have to be decoupled. So I cut the #2 fishing crimp sleeve in half using my miter saw and have to redo the plastic discs phase.
Each half #2 fishing crimp sleeve will have 3 plastic discs, one for outside of the larger diameter pulley and one for the outside of the smaller diameter pulley and one to split the two. Three total. And so with 3 plastic discs on each half crimp sleeve we have 6 total discs per thumb tack. We only had to deal with 5 before so things will be even tighter but it's fine. We have enough room.
Next, since both sets of pulleys have different speeds that vary over time, the one that is not being actively winched in at any given time will be randomly releasing slack in a chaotic way. This can lead to tangling and all sorts of problems. To resolve this, we need a automatic slack tensioner system to aid the pulley system by keeping this releasing group of pulleys in a state of good tension at all times. This I will resolve by the pictured method.
So basically a tension spring connected to a metal eyelet will at all times be trying to pull the fishing line out of alignment and draw slack out of it. So as looseness is detected, it will immediately draw that in removing it from the system maintaining taughtness everywhere at all times. This will prevent the pulleys from getting tangled or anything like that. This setup can be placed anywhere in the path between the pulley system and the joint the pulley system is to actuate.
