I came up with a design for a way to do all my downgearing 64:1 by way of pulleys that is so downscaled that it can fit onto the top of the 2430 motor and achieve the full 64:1 downgearing for BOTH directions of travel.
Here's a photo of the design drawing I made which roughly approximates what this will look like in theory:
Here's a closeup detail photo of one of the pulley downgearing stations pictured above:
Here is a photo of a thumb tack and #3 fishing crimp sleeve I bought on Amazon which will act as the basis for the downgearing pulley station:
Note: what an IMMACULATE FIT this was! I was looking through my junk bags for a sleeve for my thumb tack and nothing was a snug fit but when THIS came in the mail for the unrelated fix I mentioned earlier for the other pulley system, I knew it was perfect for the thumb tack when I saw it! It's the perfect plain bearing!
So the 64:1 downgearing system will start with two fishing lines (0.08mm in diameter 6lb test braided PE fishing line) wrapped onto the output shaft of the BLDC motor in reverse directions - one clockwise and the other counter clockwise. These strings will then travel to each of 6 downgearing stations that will each double the previous torque achieved. So downgearing station 1 will double both of the string's torque and downgearing station #2 will double that bringing the total torque to 4:1 torque. Station 3 - 8:1 torque, station 4 - 16:1 torque, station 5 32:1 torque, station 6 64:1 torque. Each station is made up of a stainless steel thumb tack with a #3 fishing crimp sleeve placed over the tack shaft forming a plain bearing pulley system. Little plastic discs will separate the various sections of this pulley system up. The discs plastic will be strawberry containers clear plastic from the grocery store (same as they use for lots of fruits, cakes, deserts, etc, the clear thin flexible plastic). The 2x torque is achieved by the string wrapping a 2x diameter pulley and a 1x diameter pulley. So every other section of the downgearing station will be 2x in diameter for this to work. Each downgearing station will be clockwise or counter clockwise rotating depending on which string it is downgearing. As the torque increases, the total wraps happening at each station decrease because the string travel is decreasing in distance by 1/2 the previous station's distance of string travel. At each station, as this phenomena occurs, a stronger fishing line can be used that is larger in diameter as needed. So only the first couple stations will use that 6lb fishing line but later stations will swap to stronger stuff since higher torques are getting involved at that point.
The thumb tacks I considered welding together or brazing together. I considered Oxy-Acetylene micro torch welding, large soldering iron brazing, micro tig welding, pulse welding with a jewelry welder, spot welding, etc. But all of these approaches I am not that experienced with. I think I'll try brazing first and if I struggle with that I'll move to fiberglass and superglue where I have the most experience.
My intention is to join each downgearing station thumb tack into its neighbor at the base and get them all to form a flat plane for stability and precise positioning. I intend to prepare the stations all together off the motor. Then when it is one solid structure with all of them glued to their neighbor and all pulley plastic discs added, at that point I can attach the whole assembly onto the 2430 BLDC motor top and suture it into place there. The teflon guidance hose attachment guide structure will also have to be part of this assembly for easy and secure attachment of the teflon hoses at the end.
