This is a slow, careful hand test of the pulley. Everything looks good. Also, I did fast tests but didn't capture a nice shot of those with good hd closeup like this. In any case, this can show you some idea of how it all looks in action so far. The motor shaft is not turning electronically but is being turned by me pulling string wrapped around it to screen left is my hand pulling. To screen bottom is a hanging bolt that is being winched (not shown its cropped out of the image).
I wanted to avoid working on the electronic actuation which is a rabbit hole in itself until I have the pulley system fully done and tested. THEN I will make it all work electronically as the next phase.
