Latest Iteration of Winch in Place Pulleys
A project log for My Advanced Realistic Humanoid Robots Project
Building bio inspired realistic looking humanoid robots to do chores and sports and stuff.
larryLarry 11/15/2024 at 04:250 Comments
Okay so here is my latest iteration of my motor mounted winch in place pulley downgearing setup completed.
I ended up doing a total overhaul of everything since my last iteration failed. In this iteration I made many small improvements. One thing I noticed is that the thumbtack shafts have a little bulbous section near their tip and I reasoned that perhaps this can catch on the #2 fishing crimp sleeve and impede it at times. So I sanded it off with a nail file so the whole shaft is now a cylinder with no protrusions. When I tested the rotation with the fishing crimp sleeve after this modification, it spun more freely than ever before by a long shot. So I think I'll do this every time going forward.
Another improvement is I added more height to the sections of the pulley, taking up all the available vertical space that used to be planned to be used for reverse direction actuation which is now being done by a tension spring instead. The added vertical space on each pulley means that contiguous loops of string wrapping have more space and so the diameter taken up by the string as it winches doesn't change nearly as much as before which means it will have more consistent downgearing through the whole duration of the winching cycle. I prefer this. It is also easier to work with for gluing on the discs and whatnot with them more spread out.
Another improvement is I added an extra pulley set on the top of the main winch in place pulley which I will use to attach a string which will be tensioned on one end by a spring and the purpose of this will be to put tension on the system to prevent derailments and ensure tight wrapping every time the winch releases its string (finger extensions). Now I may not actually need this extra tensioner pulley if the spring on the finger doing the extension actuation provides enough tension to the Archimedes pulley system and this winch in place pulley to cause them all to remain snug and tensioned, however, I think I probably should tension this winch with an additional tension spring dedicated to it exclusively even if it is just a redundancy just to play it safe and doubly ensure we get no derailments even when some issue may come up with the Archimedes pulley system. Last thing we need is a cascading of failures like Archimedes system fails so also winch in place pulley then derails and tangles so then we are really set back in the event of some unexpected issue. So better to have this redundancy.
To provide constant tension on the winch in place pulley, I have considered using elastic thread used for making DIY necklaces, using a tension spring, and using a clock spring. The latter seems like it could be the best and most reliable option due to its constant tension. I bought a few sizes to experiment with from Aliexpress. Search terms to purchase such an item were "flat spiral coil constant force spring". They are around $2 each. Considering the motor is $24, $2 to have a extra spring isn't too bad. It could really make or break the reliability I think. Now the issue is the spring is supposed to provide tension for all 32" of travel of the winch. That is a long way. My mini tape measure surely has this type of spring in it and it has that tension spring the whole time and presumably uses the same type of spring I just bought. So it is possible for a tension spring to do this for this length of travel. So hopefully one of the ones I bought works for this. If not I may have to upgear it trading tension for more travel distance. I will have to fit these extra springs into the body which may be tough. Space is VERY constrained but hopefully we can pull it off without any issues. In any case, these are going to take a few weeks to arrive so I'll be testing without it at first.
Another improvement is I made the diameter of the larger pulley of this turn in place winch bigger which means it will provide more downgearing. Not sure how much maybe an extra 5% or w/e but it's something.
I have routed the final output string using the TPFE tubing around the side of the elbow this time and then across the forearm and over to where I have setup my Archimedes pulley system from before. This Archimedes pulley system is getting a total overhaul. Many improvements planned for it. So that is up next, overhauling that. And then I will be ready to connect the turn in place winch pulley and its 2.4:1 or so downgearing with the 16:1 Archimedes pulley downgearing to achieve around 38:1 downgearing in total.
I must say it is a bit demoralizing and annoying to rebuild the winch in place pulley system 3-4 times now but I guess it's fine. That is part of the trial and error refinement process and learning process. That is how we improve on it and correct any false presuppositions we had. That is why experimentation and testing are important. So in some sense, even just having to build it just 3-4 times is a testament to the design process actually going pretty smoothly. Much better than having to do 20-30 rebuilds to get it right. So we were pretty accurate then on our overhauls and can limit rebuilds if we think it through well and do a great job. I hope this time we got it perfect and can move on to other things! Testing will tell.
Rich text editor
