There exist numerous possibilities to measure temperature. On is the Dallas DS1820 sensor. It uses a single GPIO. It is necessary to define that this GPIO is used for a 1-wire bus. And then, the 1-wire bus is referenced by its id in the sensor itself:
one_wire:
- platform: gpio
pin: GPIO12
sensor:
- platform: dallas_temp
update_interval: 5s
one_wire_id: wire1
and it shows in HA:
![](https://cdn.hackaday.io/images/1080531739216157516.png)
