An incomplete yaml file to control two LED strips for illumination using two buttons. The buttons allow only to switch between on and off. From HomeAssistant dimming is possible.
The device uses a Wemos D1 mini.
The LEDs are controlled using PWM output and are connected using a logic-level n-MOSFET (IRLU 024N). The maximum level is set to 95% to prevent the LEDs from to early degradation (at least I hope so).
The buttons used to toggle the lights include a very simple debouncing (filter).
esp8266:
board: d1_mini
# LEDs: 13, 14 (D7, D5)
# Taster: 5, 4 (D2, D1)
output:
- platform: esp8266_pwm
pin: GPIO14 #D5
frequency: 440 Hz
min_power: 0
max_power: 0.95
min_power: 0
max_power: 0.95
frequency: 440 Hz
pin: GPIO13 #D7
light:
- platform: monochromatic
output: Fenster_pwm
default_transition_length: 3s
output: Bett_pwm
# - platform: status_led
# name: "Status"
# pin:
# number: GPIO2
# inverted: true
# restore_mode: ALWAYS_OFF
binary_sensor:
- platform: gpio
pin:
number: GPIO4 #D1
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on: 50ms
on_click:
max_length: 500ms
then:
- light.toggle: Licht_Fenster
- platform: gpio
pin:
number: GPIO5 #D2
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on: 50ms
on_click:
max_length: 500ms
then:
- light.toggle: Licht_Bett
sensor:
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 300s
MaBe42
