Of course, there need also to be inputs. For example a switch or a button. I added a button to toggle the red LED. To interact between different components, the components need to have an id. So, an id needs to be added to the red LED:
light:
- platform: monochromatic
output: gpio_d7
default_transition_length: 1.5sAs can be seen, the transition length can be fractions of seconds.
To add the button or switch as an input, a binary_sensor needs to be added:
binary_sensor:
- platform: gpio
pin:
number: GPIO14 #D5
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on: 50ms # debouncing
on_click:
max_length: 1000ms
then:
- light.toggle: red_ledThe button connects the gpio pin to ground. Therefore, a pull-up resistor to Vcc is needed. This can be done using an internal pull-up. As the gpio goes to 0 when the button is pressed, inverted: true is used which provides a logic 1 when the button is pressed. max_length is used to define what is considered a click.
Now, the red LED can be toggled using the button and in addition its intensity can be changed from HA.
In HA, there is now an additional Sensors field which shows the state of the button:
MaBe42
