Status LED:
Most of the ESP boards have a status LED. There exists a primitive to directly access it:
light:
- platform: status_led
pin:
number: GPIO2
inverted: true
restore_mode: ALWAYS_OFFThis allows easily using the status LED as an indicator when programming automations in ESPhome.
HA Button:
A switch from ESPhome shows as a switch in HA and can be toggled there. However, sometimes you would like to have the equivalent of a tactile button in HA, for example to press a button in the HA companion app on a smartphone to open a garage door.
output:
- platform: gpio
pin: GPIO0
switch:
- platform: output
name: "Generic yellow switch"
output: gpio_d3
button:
- platform: template
on_press:
then:
- switch.turn_on: yellow_switch
- delay: 1s
- switch.turn_off: yellow_switch
So pressing on this button in HA turns the yellow switch on for 1 second. Similar to pressing a button for 1 second.
MaBe42
