Well, I probably should have seen this coming but the ejector servo (which was just duct taped to the side of the tin) has pulled off from the weight of the mushroom.
Mounting this is a bit awkward as I don't want to put any screws through the front of the tin. I will use some super glue and re-mount with some duct tape. That should be able to hold it!
