Here are the 1st result of the first hardware test:
- Operational voltage of the 5V buck converter is 3.5V->30V
- 30 mins in mid air, 25°C room temp, 4.7A current pull result in max 66°C board temp
- Current reading is right on, +- 24mA accuracy
A project log for PicoPD Pro - USB-C PD 3.1 PPS AVS with RP2040
Adding Power Delivery 3.1 (PD3.1) with PPS EPR AVS to our beloved RP2040 chip in Pico footprint.
